ICP Sensor O-ring (Not seal) part number - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-17-2018, 07:27 PM Thread Starter
Quoted: 7 Post(s)
I had an oil leak while driving and traced it down to my passenger side valve cover, where the ICP Sensor bolts in. I recently did work and replaced some injectors so I guess it wasn't tight enough or the ICP Sensor seal was not set properly. My ICP Sensor seal and my ICP Sensor O-ring are both damaged.
I found the part number for the ICP Sensor Seal which is W301385, but is it possible to find an ICP Sensor o-ring? So I do not have to buy a whole new ICP?
By ICP Sensor O-ring I mean the actual little o-ring above the ICP Sensor threads, not the black seal. Thanks!
Thanks all!
bahadur is offline
