EGR Dummy Valve Now, Delete Later? - Page 2 - Ford Powerstroke Diesel Forum
 26Likes
post #11 of 79 Old 06-03-2018, 08:30 AM Thread Starter
Quoted: 14 Post(s)
It's an '04 engine. Truck sticker says 12\03. I guess that means early '04. It has the square EGR cooler.
Johnny Gunz is offline
post #12 of 79 Old 06-03-2018, 08:36 AM
ZMANN's Avatar
Quoted: 3909 Post(s)
unplug the valve and see if you throw a cel ( you can clear it or let it clear itself )
if so you will want to tune that out so it won't be illuminated and so you can be alerted to other CEL worthy issues that may pop up
6.0 flush pdf
ZMANN is offline
post #13 of 79 Old 06-03-2018, 08:38 AM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
12/03 would be a late '04. The ICP should be on the passenger side valve cover.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #14 of 79 Old 06-03-2018, 11:08 AM
doubleslottedflaps's Avatar
Quoted: 174 Post(s)
What is the Ebay link for the EGR dummy valve ?
doubleslottedflaps is offline
post #15 of 79 Old 06-03-2018, 11:42 AM Thread Starter
Quoted: 14 Post(s)
It's this one.
Well, on my tablet I'm having trouble figuring out linking. It's on EBay and called a Ford 6.0 EGR Eliminator.
post #16 of 79 Old 06-03-2018, 12:56 PM
voodooridr's Avatar
Quoted: 971 Post(s)
This is the one I'm using, got it from Rudy's on Ebay
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #17 of 79 Old 06-03-2018, 01:05 PM Thread Starter
Quoted: 14 Post(s)
Are you using it alone or with plates? What is your opinion so far? It seems like an easy way to stop the damage. One member here claimed he had lower EGTs when using it.
post #18 of 79 Old 06-03-2018, 01:34 PM
Quoted: 324 Post(s)
The plug doesn't necessarily prevent an EGR cooler failure. If you have an 03 to early 04 EGR cooler with the heat exchange tubes (not plates), then it may be worth the risk. If you have the late 04 and up model, those EGR coolers aren't very reliable IMO ....... even with the flow blocked off.
bismic is offline
post #19 of 79 Old 06-03-2018, 01:52 PM
voodooridr's Avatar
Quoted: 971 Post(s)
It appears to function as advertised, I would love to delete the EGR altogether but I can't do that living here behind the iron curtain of commiefornia.
It throws a CEL every once in a while but that's easy to clear with the CTS2
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #20 of 79 Old 06-03-2018, 01:55 PM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
Yes to @bismic 's comment. A weak 04+ EGR cooler can fail and - while coolant is blocked from entering the intake with a spool - it can still run down the up-pipe and enter a cylinder through the exhaust manifold. Maybe not high probability, but possible.
I run a spool but after upgrading to a hardened EGR cooler.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
