Head studs one at a time on 57K engine? - Ford Powerstroke Diesel Forum
 23Likes
post #1 of 43 Old 05-21-2018, 09:43 AM Thread Starter
Quoted: 33 Post(s)
Garage
I am strongly considering doing head studs one at a time on my vehicle. It's got original 57K miles, no head gasket issues. I've torn up so much to do the BPD remote oil cooler that I figured I would install a few other upgrades while it's down, like the BPD billet water pump. And of course - probably the second biggest issue following the oil cooler, put in head studs.
I am in a pretty remote part of AZ and there no powerstroke machine shops within 100 miles.
So my options (it seems to me):
1. Just do the studs one at a time.
Following the torque order, pull TTY bolt, put in stud, torque to current torque. When they're all done on one side, go back around and snug them up to the recommended torque.
2. I pull the heads, clean them myself.
I can use a gauge and follow the manual to see if they're still true, or need resurfacing. Clean it as well as possible (a good simple green bath with brushing, then nice warm rinse, and air hose them dry). I inspect all the components, look for any visible cracks, like between injectors and glow plugs, and if they look good, after cleaning the block I put on a set of Felpro gaskets, put the heads on and stud them.
3. Just leave em. Wait for it to blow if it ever does. It's a 2003 motor (june 2003 build 2004 model). It might not have a problem. Ever.
This is a dedicated horse hauler.
Advice?
Mike in Cornville is offline
post #2 of 43 Old 05-21-2018, 09:51 AM
Fummins Mod
junior125's Avatar
Quoted: 2225 Post(s)
Garage
either leave it alone or do it properly
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #3 of 43 Old 05-21-2018, 10:03 AM Thread Starter
Quoted: 33 Post(s)
Garage
Spud Monkey likes this.
post #4 of 43 Old 05-21-2018, 10:26 AM
elephantrider's Avatar
Quoted: 205 Post(s)
all or not.
02 joke
Originally Posted by djone10 View Post
I just bought an 05 powerstroke 6.0.
Any tips on what should be changed/checked other than oil change??
Originally Posted by Rolfsted View Post
Everything
elephantrider is offline
post #5 of 43 Old 05-21-2018, 10:35 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
The only good thing about one at a time is that its good practice for when you have to pull the heads.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #6 of 43 Old 05-21-2018, 11:04 AM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
doubleslottedflaps is offline
post #7 of 43 Old 05-21-2018, 11:20 AM
ZMANN's Avatar
Quoted: 4008 Post(s)
i am seriously contemplating buying those
The Official ARP Web Site | Kits
6.0 flush pdf
ZMANN is offline
post #8 of 43 Old 05-21-2018, 11:23 AM
ZMANN's Avatar
if i did one at a time
i would remove one and bring the new ARP up to the torque spec of the old TTY ( you would need to set a guesstimate or check one of the installed ones since the TTY has you do some 90* turns as a final and not a torque spec) then i would run up to the ARP spec in a few increments using the pattern
joe blow likes this.
6.0 flush pdf
ZMANN is offline
post #9 of 43 Old 05-21-2018, 11:46 AM
joe blow's Avatar
Quoted: 150 Post(s)
I have heard of it being done with success. Then again you may have a mildly compromised head gasket that doesn't show any symptoms, then you disturb it by loosening the OEM fastener then clamp it down with way more force and now you have an issue. That would suck.
I have been into the engine more times than I want to admit and no matter which way you slice it, it kinda sucks after a while
I personally wouldn't do it but good luck if you do. Like mentioned before, do it correctly or just wait until you really need to do it....then do it properly.
Good Luck
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #10 of 43 Old 05-21-2018, 02:55 PM
Quoted: 190 Post(s)
thems the ones to get
