About to take trip noticed issue would you go? - Ford Powerstroke Diesel Forum
 6Likes
  • 3 Post By JustinOOO9
  • 2 Post By ZMANN
  • 1 Post By Chris
post #1 of 7 Old 04-19-2018, 02:28 PM Thread Starter
2005 power stroke e350 van with almost 400k all stock, just bought it and about to leave on a trip from chicago to huston texas and back, not towing just passengers.
I just noticed its loosing some coolant and there is oil in the degas bottle. Weird thing is oil/coolant temp difference is only 6 to 10deg but it is cold here and the truck doesn't get to full operating temp. Also no smoke and runs good. Would you take it on this trip?
Thanks.
clayracer is offline
post #2 of 7 Old 04-19-2018, 03:37 PM
JustinOOO9's Avatar
Quoted: 1670 Post(s)
Garage
Feedback Score: 3 reviews
Not a chance...
Degas could just need a new cap but at 400k miles I highly doubt that as much as I would like to be positive.
Oil in the coolant is BAD JUJU....
You could almost rent a van for cheaper then what it could cost for a tow, hotels, and repair if that thing goes on the trip. Then you still need to cross your fingers the shop closest to you is qualified.
ZMANN, jokester00 and Chris like this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #3 of 7 Old 04-19-2018, 03:41 PM
ZMANN's Avatar
Quoted: 4003 Post(s)
rent a van and save yours
if it is truly oil in the coolant i would not risk it
6.0 flush pdf
ZMANN is offline
post #4 of 7 Old 04-19-2018, 04:38 PM
ChrisSki's Avatar
Quoted: 587 Post(s)
I definitely agree with the above. Also, with passengers, if its family, and the first trip is awful, than they will hate that vehicle forever. Some of our significant others are not as excited as we are about the vehicles, one break down and, wow. If those passengers are for fare or business, than you could be responsible for their lodging.
Best case this fails catastrophically on the road, the truck will be down 36 hours; worst case where its the heads, could be two weeks while the heads are decked and fixed.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
post #5 of 7 Old 04-19-2018, 05:13 PM
jokester00's Avatar
Quoted: 502 Post(s)
Garage
Agree with the above statements. Not a chance that thing would leave my driveway...
I like the idea that @ZMANN said - rent one! If yours breaks down on the trip, it could end up costing you more than renting one just to get it to a shop to be fixed.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #6 of 7 Old 04-19-2018, 05:30 PM
Sock Puppet's Avatar
Quoted: 575 Post(s)
Negative, Ghostrider.
400K is a significant amount. How many hours are on the engine? If you just bought it you may need to do some serious thinking and researching before making a move. I don't want to throw a shadow over your new wagon, but these engines can get expensive very quickly. Consider what you have in it and trouble shoot it so you'll have an idea how much it's going to cost to fix. Then decide if you need to cut your losses.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #7 of 7 Old 04-20-2018, 04:28 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
ZMANN likes this.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
