Need Help: Part Identification 2003 6.0 - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 11 Old 04-06-2018, 05:38 PM Thread Starter
Quoted: 3 Post(s)
Hello everyone I am new to the PSD world and I am looking for a part number or part identification.
I have a 2003 6.0 and I am looking for the O-Ring that goes on the High Pressure Fuel Rail Plug that uses a 6MM allen head. I see a smaller plug and then this larger one both on the top but I am having ZERO luck finding any names or even O rings for this plug I am in the process of a huge undertaking and I ran across another part that needs replaced. Thanks for any help.
Low50s is offline
post #2 of 11 Old 04-06-2018, 06:58 PM
Quoted: 324 Post(s)
IIRC Ford doesn't recommend replacing o-rings on these plugs. Take it to a local hydraulic shop and have them match it (viton would be a good material to use).
fordsvtparts likes this.
bismic is offline
post #3 of 11 Old 04-07-2018, 04:12 AM Thread Starter
Quoted: 3 Post(s)
This is what I would have done but the current O-ring is destroyed. I am changing a injector on my truck and when I looked stuff over before I put valve cover back on I found that the O-ring that I am searching for was smushed out of the plug
Low50s is offline
post #4 of 11 Old 04-07-2018, 04:43 AM
Quoted: 324 Post(s)
It might help to post a pic of the oil rail location and the plug itself.
I have this part number for an oil rail test plug o-ring, but don't know the size:
3C3Z-9C064-BA
https://www.tascaparts.com/oem-parts...ng-3c3z9c064ba
The test plug itself is part # W302297, but I have a note that it comes w/ the dummy plugs (which is for the late 04's and up). I am not 100% that it is correct for your 03.
https://www.tascaparts.com/oem-parts/ford-plug-w302297
Maybe @fordsvtparts can help - or you can stop by a dealership and ask to see the parts (o-ring and plug) listed above.
bismic is offline
The Following 2 Users Say Thank You to bismic For This Useful Post:
fordsvtparts (04-09-2018)
post #5 of 11 Old 04-08-2018, 04:16 PM Thread Starter
Quoted: 3 Post(s)
I called Tousley Ford and had some help trying to locate what I needed
I think this is the O ring
3C3Z-9C064-AA - O RING
Just wanted to post my findings. I hope this may help anyone else that is needed
Low50s is offline
The Following User Says Thank You to Low50s For This Useful Post:
ZMANN (04-08-2018)
post #6 of 11 Old 04-08-2018, 04:35 PM
Quoted: 324 Post(s)
@fordsvtparts - can you verify this?
What is the difference between AA and BA ?
partyman97_3 likes this.
bismic is offline
post #7 of 11 Old 04-08-2018, 05:19 PM Thread Starter
Quoted: 3 Post(s)
The BA price was way better than the AA I bought I paid $8 for the O ring from the local ford dealer.
Low50s is offline
post #8 of 11 Old 04-09-2018, 04:16 PM
fordsvtparts's Avatar
Quoted: 143 Post(s)
The 3C3Z-9C064-BA is the correct O ring for the W302297. Since the plug is used on the later 2004-up oil rail, the Oring comes comes with the stand pipe kit.
I come up 03 fuel rail plug number of W300091 (smaller of the two), which also uses the 3C3Z-9C064-BA. The 3C3Z-9C064-AA is slightly larger. It's kind of a bad listing on our end, but the larger "AA" is shown as being used between the discharge tube and branch tube (03-04).
bismic and jokester00 like this.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
The Following 2 Users Say Thank You to fordsvtparts For This Useful Post:
jokester00 (04-09-2018)
post #9 of 11 Old 04-09-2018, 05:02 PM Thread Starter
Quoted: 3 Post(s)
So I got the wrong O ring bought and installed?
Low50s is offline
post #10 of 11 Old 04-09-2018, 05:22 PM
Quoted: 143 Post(s)
Well...that's where are listings are not very good. There's a huge difference between these two numbers. You couldn't possibly use the wrong O ring. The 3C3Z-9C064-AA is on the left, 3C3Z-9C064-BA on the right.
bismic likes this.
