Replaced radiator and now trans. won't go into gear. - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 27 Old 02-21-2018, 05:56 AM Thread Starter
Quoted: 18 Post(s)
I replaced my radiator on my 06 last Friday. Drove for three days no problem. Then yesterday morning on my son's drive to school, transmission all of the sudden would not go. I put it in gear and looked under and driveshaft not turning so the problem is in the trans. I let it set a few minutes and fired back up and it went in gear for a few minutes then it stopped moving again. I only lost about a quart of fluid during replacement of radiator. Wondering if its a coincidence since trans. has 265K miles on it, or new radiator(Performance) could be an issue. Any thoughts before i have it towed to tranny shop?
05 Pstroker is offline
post #2 of 27 Old 02-21-2018, 06:08 AM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
It could also be a transfer case issue.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #3 of 27 Old 02-21-2018, 06:08 AM
Heavy_GD's Avatar
Quoted: 3121 Post(s)
Garage
Feedback Score: 4 reviews
Did you take the plug out of the connections for the trans lines?
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #4 of 27 Old 02-21-2018, 06:42 AM
ZMANN's Avatar
Quoted: 3910 Post(s)
you did check the fluid level before posting correct ?
Heavy_GD likes this.
6.0 flush pdf
ZMANN is offline
post #5 of 27 Old 02-21-2018, 06:58 AM Thread Starter
Quoted: 18 Post(s)
Yes I did.
post #6 of 27 Old 02-21-2018, 07:01 AM Thread Starter
Quoted: 18 Post(s)
Yes I did. Before I added the Quart it checked out full, but I still added the quart that I lost and it showed no different on the dipstick.
ZMANN likes this.
post #7 of 27 Old 02-21-2018, 07:50 AM
Quoted: 12 Post(s)
Is there trans fluid in the coolant, or vise versa?
Did Performance provide the quick disconnect fittings for the 05 model, or did you reuse your old ones?
05 Pstroker likes this.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #8 of 27 Old 02-21-2018, 07:53 AM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
I wonder if there could have been something in the trans cooler that made its way to the trans? You did top off with SP or LV, right?
2018 F250 4X4 CC LB 6.2
2004 F250 4X4 CC SB Sold (Miss you Sarah!)
DMc is offline
post #9 of 27 Old 02-21-2018, 07:58 AM
ZMANN's Avatar
sounds like a coincidence since it was fine for three days
Performance makes a good product
i agree though check for cross fluid contamination
and dbl check fluid level ( the 5r is hard to read and getting a dry surface on the indicator is tricky )
your drive shaft wont spin unless your tires are moving
6.0 flush pdf
ZMANN is offline
post #10 of 27 Old 02-21-2018, 08:01 AM Thread Starter
Quoted: 18 Post(s)
I used the old fittings. Performance did not supply new ones. I just unscrewed from old fittings and screwed back into new fittings on new radiator.
