Replaced radiator and now trans. won't go into gear. - Page 2 - Ford Powerstroke Diesel Forum
 8Likes
post #11 of 27 Old 02-21-2018, 08:04 AM Thread Starter
Quoted: 18 Post(s)
Originally Posted by DMc View Post
I wonder if there could have been something in the trans cooler that made its way to the trans? You did top off with SP or LV, right?
Yes.......
05 Pstroker is offline
post #12 of 27 Old 02-21-2018, 08:06 AM Thread Starter
Quoted: 18 Post(s)
No fluid in coolant and I haven't checked for coolant in fluid yet.
post #13 of 27 Old 02-21-2018, 08:24 AM
jokester00's Avatar
Quoted: 461 Post(s)
Garage
When you checked fluid level, was the truck running and was it at operating temp? Can't remember if these dipsticks have a cold setting or just the hash marks when warm.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #14 of 27 Old 02-21-2018, 08:44 AM Thread Starter
Quoted: 18 Post(s)
-jokester
Running and full temp. 196*. Yes this one had cold and warm hashes.
jokester00 likes this.
post #15 of 27 Old 02-21-2018, 09:13 AM
jokester00's Avatar
Quoted: 461 Post(s)
Garage
Hmmmm... It just seems like more than a coincidence that you started having issues a couple days after the repair.
-jokester
05 Pstroker likes this.
Edge EAS EGT probe
Last edited by jokester00; 02-21-2018 at 09:16 AM. Reason: OOPS...saw it was aftermarket.
post #16 of 27 Old 02-21-2018, 09:26 AM Thread Starter
Quoted: 18 Post(s)
Just had it towed to tranny shop. His initial diagnosis, without dropping pan yet, is something has dislodged and has gotten into filter; going off of it stalling and then letting it sit and it works for a bit then quits again. Hope it is nothing major. He will have the pan off sometime today and I'll get back.
post #17 of 27 Old 02-21-2018, 09:29 AM Thread Starter
Quoted: 18 Post(s)
Originally Posted by ZMANN View Post
your drive shaft wont spin unless your tires are moving
Understood. I was just ruling out the rear end.
ZMANN likes this.
The Following 2 Users Say Thank You to 05 Pstroker For This Useful Post:
ZMANN (02-21-2018)
post #18 of 27 Old 02-21-2018, 10:55 AM
Quoted: 12 Post(s)
Interesting... I thought the quick disconnect trans line fittings from the old stocker would not be compatible with the new radiator from Performance. Guess I learned something new today.
You have an 06, right? Was it one of the all aluminum ones from Performance?
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #19 of 27 Old 02-21-2018, 11:30 AM Thread Starter
Quoted: 18 Post(s)
Yes it s an 06 and yes an all aluminum. It had a coupling that worked with the fitting that screws into old radiator or you could take the necked down coupling out and it fits another model from what I remember.
post #20 of 27 Old 02-21-2018, 11:32 AM Thread Starter
Quoted: 18 Post(s)
Model #2944
