It is What IT is
Quoted: 432 Post(s)
Being we have different year tricks, not sure if Max AC and recirc button does the same thing. But you can look under the hood at the heater core hose and see if you have the valve. It will be on the inlet heater core hose, and will have a small grey vacuum line attached to it.
Attachment 640274
yes I have that valve. So I guess I need to have my son hit the recirc button to see what the valve does. I never use the recirc but after trying it I may just do that if the results are positive.
Thank you
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
