B&W Turnover Ball Hitting Shock - Page 2 - Ford Powerstroke Diesel Forum
 2Likes
post #11 of 15 Old 07-25-2017, 08:19 PM
ZMANN's Avatar
Quoted: 4030 Post(s)
Some pics from a similar type issue the OP asked me to share
6.0 flush pdf
ZMANN is offline
post #12 of 15 Old 07-25-2017, 08:32 PM
ZMANN's Avatar
Here are the pictures from @jbaum02 and his comments
Here's my pics. There's one pic with blue tape over the place where the hitch hits the shock. I did this after I trimmed the bracket some to see if it still hit. Doesn't look as bad now, but you can see it torn the tape just a little where it's still contacting.
ID:	637930   Click image for larger version
ID:	637938   Click image for larger version
ID:	637946   Click image for larger version
6.0 flush pdf
ZMANN is offline
post #13 of 15 Old 07-25-2017, 08:53 PM
Gaius's Avatar
Quoted: 78 Post(s)
You could always grind the corner flat on the bracket, and if that's not enough cut off the little round nub that holds the shock bracket, and reweld it inward some.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #14 of 15 Old 11-29-2017, 06:57 PM Thread Starter
Quoted: 12 Post(s)
Figured I'd give an update on my solution. After talking with B&W, I drilled two new holes through the outer hitch bracket and frame, installed 1/2" bolts in the new holes, and removed the C shaped bracket completely.
I've pulled a skid steer on a 32' gooseneck several times and today I hauled a load of cattle in a 28' gooseneck. The hitch doesn't seem to have shifted even a tiny bit. Seems to be working just fine.
Heavy_GD likes this.
jbaum02 is offline
The Following 2 Users Say Thank You to jbaum02 For This Useful Post:
ZMANN (11-29-2017)
post #15 of 15 Old 11-30-2017, 05:35 AM
Heavy_GD's Avatar
Quoted: 3168 Post(s)
Garage
Feedback Score: 4 reviews
Great update. Thanks for coming back
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
