URGENT. Official fuel pressure statement? - Ford Powerstroke Diesel Forum
 26Likes
post #1 of 31 Old 07-24-2017, 11:32 AM Thread Starter
Quoted: 6 Post(s)
I recently got some diesel with 30-40% gasoline from the local station. My truck won't start and I'm only seeing single digits fuel pressures. The local "head diesel tech" at the Ford dealership says that the 6.0, not being a common rail, only needs a few pounds of pressure. I told him 45 was absolute minimum and he flat told me I was wrong... I'm desperately looking for some proof from Ford so that I can prove that some damage was done... Until then, I'm on the hook for the bill..
Sent from my ZTE A2017U using Tapatalk
2003 F250 6.0 powerstroke 333k and counting
2008 F450 6.4 powerstroke 210k and counting
stoverjoe is offline
post #2 of 31 Old 07-24-2017, 11:41 AM
AaronB.F250's Avatar
Quoted: 10 Post(s)
I do not think Ford covers bad or contaminated fuel.
Sent from my VS995 using Tapatalk
2006 CCLB Lariat 6.0
4"D.P 5" straight pipe. APR studs. EGR delete. SCT X4 running looney wild. PHP Atlas 80
Coolant By-Pass Filter. Blue Spring. H&S Mini Maxx to monitor along with Glowshift Pyro, Boost Gauge. Dummy plugs. Stand pipes. LED interior, Reverse lights, 6000K Fogs. 6000K Headlights, High Idle mod.
2009 F-450xlt 6.4 6spd
9' enclosed utility body. Work Truck
AaronB.F250 is offline
post #3 of 31 Old 07-24-2017, 11:43 AM Thread Starter
Quoted: 6 Post(s)
Sorry, not what I meant... The fuel station will pay but not if Ford says there is nothing wrong.
post #4 of 31 Old 07-24-2017, 11:45 AM
Beerent93's Avatar
Quoted: 143 Post(s)
Garage
if in fact it has gasoline in the mix you need to talk to your fuel station you bought your fuel at. It isn't hard for a driver while dumping fuel in the in ground tank to make a mistake and dump a few hundred gallons in the diesel tank accidentaly. While they are dropping fuel the fuel tanker drops at a rate of about 300 gallons per minute. He could have accidentally started dropping what he thought was diesel in there and put gas in there, than stopped it and finished dumping diesel. It also could be that the driver had a few hundred gallons of gas in the compartment left on his truck and created what is called trans mix by filling up that compartment on his trailer with diesel. These are unfortunately things that happen while delivering fuel. I would start there and if that in fact is the case the gas station where you bought the fuel is on the hook and they will go after the delivery service that provided the fuel.
Beerent93 is offline
post #5 of 31 Old 07-24-2017, 11:46 AM
Heavy_GD's Avatar
Quoted: 3146 Post(s)
Garage
Feedback Score: 4 reviews
So, for fuel pressure only... I have seen these trucks run on single digit fuel, but they wont make any power.
@kaya
john galt likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #6 of 31 Old 07-24-2017, 11:47 AM Thread Starter
Quoted: 6 Post(s)
Yes, already did that. They have multiple claims they are sending to corporate. My issue is that t the local. "head diesel tech" thinks 5psi ,down from 60, is completely fine...
post #7 of 31 Old 07-24-2017, 11:48 AM
Beerent93's Avatar
Quoted: 143 Post(s)
Garage
Side note I would get a fuel sample and have it verified, doesn't matter what ford says at that point, proof is in the pudding.
TaintlessEd likes this.
post #8 of 31 Old 07-24-2017, 11:49 AM
Quoted: 10 Post(s)
Not sure if I would go back to that garage after this
@toren302
post #9 of 31 Old 07-24-2017, 11:51 AM Thread Starter
Quoted: 6 Post(s)
Never have let them touch my diesels because I know more than they do... But their shirts have blue ovals on them..
post #10 of 31 Old 07-24-2017, 12:07 PM
Quoted: 795 Post(s)
get a second opinion at a different dealer?
2007 F250 Lariat Outlaw
174k
Stock Motor
5" MBRP Catback
Boudah is offline
