Looks like it may be time... HG Job - Page 14 - Ford Powerstroke Diesel Forum
 165Likes
post #131 of 202 Old 08-31-2017, 01:41 PM
looking4psd's Avatar
Quoted: 12 Post(s)
Originally Posted by G8orFord View Post
Showing my ignorance, but where does the blue o-ring go? Is it for a different injector or something?
Sent from my XT1650 using Tapatalk
Happen to be the size of the connector o-ring? Those are blue, but usually not light blue...
G8orFord likes this.
looking4psd is offline
The Following User Says Thank You to looking4psd For This Useful Post:
G8orFord (08-31-2017)
post #132 of 202 Old 08-31-2017, 01:57 PM Thread Starter
G8orFord's Avatar
Quoted: 2594 Post(s)
Garage
Duh, told you I was showing my ignorance. Thanks.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #133 of 202 Old 08-31-2017, 03:46 PM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1101 Post(s)
The plug....
Sent from my iPhone using Tapatalk
@loxdce
LoxDiesel is offline
post #134 of 202 Old 08-31-2017, 06:20 PM Thread Starter
G8orFord's Avatar
Garage
Yeah, it was too obvious. I was tunnel visioned on the injector itself. I had a lot going on in my head today with some personal issues and probably shouldn't have even been working truck. I did get the rear seal in, the other head on and four injectors in. It turns through freely and the rocker geometry looks pretty good, but since the lifters aren't pumped up, there's not much I can do at this point except hope there's no interference issues with the Stage 1 cam.
Hoping my glow plugs, flexplate bolts and IPR screen and seals get here early enough tomorrow to swing it back in. If not, I may reuse the flexplate bolts and swing it in anyway.
SparkyF250 likes this.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #135 of 202 Old 08-31-2017, 08:52 PM
joe blow's Avatar
Quoted: 153 Post(s)
Good progress for you today!
Me........ I Got it back in the truck today.
I will say that if I did this often I would buy the rear seal tool or make an adapter for the rear flexplate spacer. It took me a little while to seat it and be happy with the results. All in all it turned out fine!
While she was out I even changed the crank bearings. This pseudo rebuild has been an adventure but well worth it. She will be running by Sunday.
I need to install my adii as well.
G8orFord and SparkyF250 like this.
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #136 of 202 Old 09-01-2017, 05:13 AM Thread Starter
G8orFord's Avatar
Garage
I agree, if I did this more than a couple of times a year, I'd buy the seal installer tool too. I actually had a local guy that said he'd rent me his for $50 non-refundable, which is reasonable. I decided to go ahead and try the flange method first. It worked like a champ, just a little slow. I used 4 boils spaced out and pulled it down pretty evenly. The plastic ring that came with the seal worked perfectly with the flange to push it up flush with the back cover. Then a blunt punch to set the rubber side nice and flush too.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #137 of 202 Old 09-01-2017, 07:13 AM
joe blow's Avatar
Quoted: 153 Post(s)
How funny......I pretty much did the same thing but I used a plastic block to lightly tap the rubber in flush.
Not sure if you're doing the front but if you do, tap in the sleeve separate after loctiting it using wood then draemit in with the balancer.
Joe
joe blow is offline
post #138 of 202 Old 09-01-2017, 07:21 AM
djmaguire's Avatar
Quoted: 1588 Post(s)
Garage
... then draemit in with the balancer. ...
What Does DRAEMIT Stand For - Meaning Of DRAEMIT
The more I read, the more I think that I may not be spiritual enough for a full 6.0 engine rebuild...
ZMANN, scparrish and SparkyF250 like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #139 of 202 Old 09-01-2017, 07:37 AM
joe blow's Avatar
Quoted: 153 Post(s)
Haha
Dang auto correct!!!!
Drive it*
Joe
joe blow is offline
post #140 of 202 Old 09-01-2017, 08:00 AM
ZMANN's Avatar
Quoted: 4014 Post(s)
loctiting .
wrestling move or from a porn flic ?
6.0 flush pdf
ZMANN is offline
