Aftermarket Warranty? - Page 2 - Ford Powerstroke Diesel Forum
 13Likes
post #11 of 25 Old 07-02-2017, 10:08 AM
RedneckGirl's Avatar
Quoted: 40 Post(s)
I had purchased an extended warranty for my Excursion. It was sold to me as complete coverage for everything that wasn't considered "normal wear and tear." Well, I lost overdrive and needed either to rebuild my tranny or replace it. That turned into the fight from hell. Not only did I have to pony up every cent FIRST, the paperwork battle made me want to run head first into a wall. The list of shops they approved work from was so small in my area I felt uncomfortable not being able to use someone who was known to be reputable.
I read the fine print. But, the company amended the contract and sent me notification of change of spec. Literally 4 grand thrown down the toilet with another nearly 3 grand in a new transmission.
These warranties are often sold from one company to another, or after receiving negative reviews a new sister company is formed and they take over the other company's customers.
I'd cash out and walk. You can purchase a lot of parts and labor for that money. Yes, a new engine will cost you far more, but put your money in preventative maintenance and save yourself the hassle.
ZMANN and Sock Puppet like this.
~Shayna
2008 6.4L 4X4 Lariat
6.4L w/SCT Livewire, Deleted, and loved! About to hit 200,000 miles!
RIP 2003 7.3L Limited Excursion 4X4 & 2007 6.0L Lariat FX4
RedneckGirl is offline
post #12 of 25 Old 07-02-2017, 01:59 PM Thread Starter
DieselPatriot's Avatar
Quoted: 11 Post(s)
Originally Posted by maddawg89 View Post
Well, they paid for a turbo and water pump on my truck..... I only got the basic service though, that's all they would sell me.
My buddy whose shop does all my work usually doesn't have issues getting them to do studs
Sent from my SM-J727VPP using Tapatalk
Did you have Route 66 warranty or someone else?
I am still on the fence about this
I have Main Street aka all of them.
Here is some of the things it covers and my paper says it covers more.
Still welcome on people input. If I do cancel it and get my 3,300.00 back what should I buy? (Dont say lift kits or tires, I want to keep my truck running good and safe....and I already have that stuff )
www . eastriverfcu . com/ Documents/Miscellaneous/Route66Brochure .aspx
2007 6.0 - 35x13.5tty.20, 6" RC/PC Lift, Dual Steering Stabilizers, 1A tow mirrors, Drilled & Slotted Rotors, AirDog II-4G DF-165, SCT x4 with custom tunes by ID & QT, KC Turbo Wheel (10 Finn/Blade),
DieselSite SS yPipe, True 4" Diamond Eye Turbo Back, Warren 175/30 injectors (soon)
Currently down & buying parts. I know I am forgetting stuff but ill try and update.
DieselPatriot is offline
post #13 of 25 Old 07-02-2017, 02:05 PM
Master_Chase's Avatar
Quoted: 519 Post(s)
Put it in a rainy day fund
Take your family on a vacation
Put it in your kid's college fund
Buy gauges/monitor
Put it in your future bulletproofing fund
etc, etc, etc
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #14 of 25 Old 07-02-2017, 02:15 PM
ZMANN's Avatar
Quoted: 3962 Post(s)
put it in a savings account that 3300.00 $ won't give you lip and headaches when it comes time for a repair
it won't keep your truck in the shop waiting for an inspector
it won't ask for receipts and service records ( a friggin pain if you do your own service)
no one on here ever recommends aftermarket warranties. the only one worth extending is Oem
6.0 flush pdf
ZMANN is offline
post #15 of 25 Old 07-02-2017, 02:21 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
I wasted money on the warranty I got when I bought my truck years ago. The only thing I ever got repaired that was covered by the warranty was the rear main seal.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #16 of 25 Old 07-02-2017, 02:22 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
Heres what I would do; Get a 30 psi gauge on that cooling system of your truck. Take it for a nice long drive and see what the pressure is. If its 8-12 psi I would rat hole that money for sure.
You can also look at the transmission to make sure its sound, which it most likely is. If that trucks been cared for and the head gaskets are good your nuts to buy ANY warranty.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #17 of 25 Old 07-02-2017, 02:24 PM
ZMANN's Avatar
i bet it still cost you money ?
everytime i had my warranty cover something I was on the hook for some portion of the repair that was not covered
like evacuating and recharging the AC when they diod the compressor
or the dagas bottle that was not covered because Ford didn't call it an overflow and on and on
not to mention they only paid 75 bucks an hout and my Ford dealer was 110.00 so i paid the difference
6.0 flush pdf
ZMANN is offline
post #18 of 25 Old 07-02-2017, 02:55 PM
Durapig Eater's Avatar
Quoted: 163 Post(s)
I had a Mopar warranty on my 6.0, bought the truck from a dodge dealer. It was power train plus. Covered 2 head jobs, 10 injectors, rear main seal, bed plate leak, inner axel seals, hpop replacement and a rental every time it was in the shop, which was a lot... I had a $50 deductible and I had to pay for bad sensors. They wouldn't pay for oringed heads, even after the second head job, had to buy my own arps. It was 4 years unlimited mileage for $2500.
But they still payed out more than I paid for the whole truck in 4 years.
Durapig Eater is offline
post #19 of 25 Old 07-02-2017, 03:14 PM
ZMANN's Avatar
NOTED
buy a 6.0 from a Dodge dealer and you can get a decent warranty
SparkyF250 likes this.
6.0 flush pdf
ZMANN is offline
post #20 of 25 Old 07-02-2017, 03:26 PM
G8orFord's Avatar
Quoted: 2567 Post(s)
Garage
Originally Posted by ZMANN View Post
NOTED
Probably not anymore. I bet they learned their lesson with @Durapig Eater .
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
