Can I prime LPOP system with turbo out - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Shim
LinkBack Thread Tools
Old 06-09-2017, 03:32 PM Thread Starter
chetspencer's Avatar
Quoted: 8 Post(s)
Garage
Greetings, I'm just about done rebuilding my 6.0 and I've just filled it with 4qts in the oil filter supply and the 10 qts in the turbo oil drain tube. Injectors are out as I just want to get oil pressure in the lpop system before I install the HPOP rails to get the lifters and rockers happy. I'm thinking I can block off the Turbo oil supply port in the Oil cooler cover to do this. Maybe I'm over thinking it and should just keep putting it back together and deal with it in my Excursion all buttoned up. Thanks for your feedback. I do plan on filling the HPOP rails and possibly use my vacuum extractor to pull a vacuum on the rails to get the air out as well.
Name:	Almost done 6.0 rebuild.jpg
6.0 heads are like onions: Peels off more than the skin and they'll make you cry.
chetspencer is offline
Old 06-09-2017, 07:11 PM
Quoted: 692 Post(s)
Sure, just block the turbo feed port. Will be fine
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
Old 06-09-2017, 08:28 PM
Quoted: 37 Post(s)
On the past couple engines I have built, I have actually filled the oil under pressure while still on a stand. First, I pressurize the LP system and pump in around half the oil. Then, I do the HP system with the small plugs removed from the rails. I pump oil into the HP system until I get no bubbles coming from them.
Last one I did, I had over 500psi on the first crank. FICM relay was out. Put the relay back in, and she lit right up and idled smooth as a babys bottom!
I used a paint pressure pot. Google it and you will see pictures of what I am talking about. Made up some fittings with some old fuel line parts and old turbo feed line.
LP I went in the turbo feed port using an old feed line cut in half.
HP I went in one of the plugs. Used some old fittings from the fuel filter housing and some old fuel lines.
I'm sure I can dig up pics if you need.
kaya and G8orFord like this.
Shim is offline
Old 06-10-2017, 07:28 PM Thread Starter
Quoted: 8 Post(s)
Garage
Thank you Kaya and Shim, excellent feedback!! Sorry I didn't respond sooner I've been going like gang busters taking my old engine out of my Excursion.
