Coolant choices - Page 21 - Ford Powerstroke Diesel Forum
 186Likes
post #201 of 229 Old 09-28-2018, 11:11 AM
ZMANN's Avatar
Quoted: 3736 Post(s)
20k already ? wow
6.0 flush pdf
ZMANN is offline
post #202 of 229 Old 09-28-2018, 12:25 PM
roverjosh's Avatar
Quoted: 36 Post(s)
Garage
@G8orFord , Thank you for the info. What is sad, is that I am still so new, I don't have enough posts to see links etc....
bump
bump
bump...
kidding, all will change soon enough.
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #203 of 229 Old 09-28-2018, 01:26 PM
ZMANN's Avatar
6.0 flush pdf
ZMANN is offline
post #204 of 229 Old 09-28-2018, 06:05 PM
G8orFord's Avatar
Quoted: 2402 Post(s)
Garage
Originally Posted by ZMANN View Post
20k already ? wow
With my son driving it now, it may be closer to 25k. LOL He keeps the tires pretty hot on it.
ZMANN, SparkyF250 and roverjosh like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #205 of 229 Old 10-08-2018, 05:58 PM
F250powerstroker's Avatar
Quoted: 6 Post(s)
I had a real ****ty mechanic who installed used parts, put a dorman oil cooler on and left metal needle bearings in my motor. Prior to this guy messing with my motor I had oil and coolant temps 5-10 degrees delta. He put ford gold and fords oil in my motor with out my appoval.
F250powerstroker is offline
post #206 of 229 Old 10-09-2018, 08:04 AM
Quoted: 4 Post(s)
It's hard to trust anyone to do right by your truck, at least for me it is. Gotta put potential mechanics through a gauntlet before they can start taking apart your baby. I work a busy schedule but i was determined to do a full coolant flush, while not "difficult" it's very time consuming. I was looking for a mechanic that worked on diesels, talked to a few of them and some were immediate "Nopes". I told them i would be willing to supply distilled water to ensure it's done right, one guy said water from the tap was better for the truck, something along the lines of "if it's good enough to drink; it's good enough for your truck"...Dafuq? another one said he only uses the "best stuff" in regards to coolant and that he won't use the ford gold garbage, i was hopeful... until he told me it was gonna cost about 25 buck for all the coolant! more tap water i guess...
Ended up doing it myself, may have gone overboard as i changed the T-stat out, installed Fumoto valves cause of that damned starter (installed a 6.4 while i was there) bought 35 gallons of distilled water ($0.76 a pop) and spent the Saturday flushing old BARF out. while it took forever and i could taste coolant for the next 2 days, I'm glad i did it, because no way was anyone gonna put that much effort into such a mundane task. i think my deltas may have gone up since then, but that's for another time!
2004 F250 King Ranch AKA B.A.R.F. - Big As$ Red Ford
Turbo back 4" | EGR Delete | Stand pipes | Dummy plugs | Blue spring | "Zoodad" mod
S&B CAI | Dual steering stabilizer | Butterfly throttle body delete | CAC tubes and elbow upgrade
Coolant & Oil acc. filtration | Fumoto block valves | Edge CTS II | Backup cam | EAS Pyro
Coolant flush - Restore & Restore+ | Rotella ELC | Delo 400 LE | Archoil AR9100
Saigachris is offline
post #207 of 229 Old 10-29-2018, 04:19 PM
TexasTex's Avatar
Quoted: 14 Post(s)
Garage
I'd have been quite angry over that. When I pay someone to work on my vehicles, they need to clear with me, what goes into it.
2003 SRW 6.0
TexasTex is offline
post #208 of 229 Old 12-22-2018, 05:19 PM
letsmow10's Avatar
Quoted: 77 Post(s)
Garage
Saw this at Walmart tonight... I don't know anything about it but it could be another option.
Sent from my SM-G965U using Tapatalk
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes
letsmow10 is offline
post #209 of 229 Old 12-23-2018, 10:07 AM Thread Starter
SparkyF250's Avatar
Quoted: 2882 Post(s)
Garage
Didn't see any specs on it. I wouldn't use it unless it's clearly marked Cat EC-1
Rotella ELC is only about $17 a gal for concentrate at TSC or Advance
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is online now
post #210 of 229 Old 12-23-2018, 12:38 PM
ChrisSki's Avatar
Quoted: 490 Post(s)
This is formulated for all cars foreign and domestic and light duty trucks. Prestone says this. Since ours are PowerStrokes, I Would stay away. I think we're a little bigger than light duty.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
