Coolant choices - Page 20 - Ford Powerstroke Diesel Forum
 186Likes
post #191 of 229 Old 09-01-2018, 11:20 AM Thread Starter
SparkyF250's Avatar
Quoted: 2880 Post(s)
Garage
Originally Posted by NCFX4 View Post
Or, as I look at it maybe just pull one of my filter lines and backflush from there?
Sent from my iPad using Tapatalk
Not if it's a bypass, to backflush you have to go in under the cap on the oil cooler. That's what the IPR manifold and the Extreme (fix-ur-6) adapter replaces. Gives you a straight shot thru the oil cooler.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
post #192 of 229 Old 09-01-2018, 11:25 AM
Quoted: 17 Post(s)
OK. Going outside to spec it out. When I did my homemade setup I used a filter block from a Class 8 truck dealer and that uses a filter with at least a 5/8Ē thread if not 3/4Ē. Iíll be changing the filter soon and Iíll check that.
NCFX4 is offline
post #193 of 229 Old 09-01-2018, 11:28 AM
Quoted: 17 Post(s)
Iím looking for pics on the web but guessing that your manifold mounted next to the rad has a spin on underneath?
NCFX4 is offline
post #194 of 229 Old 09-02-2018, 08:28 AM Thread Starter
SparkyF250's Avatar
Garage
That's an IPR full flow, cleanable filter. The spin on filters only have an 1/8" hole if you look inside. The manifold replaces the cap on the oil cooler, takes the coolant as it leaves the oil cooler, filters it before it goes into the EGR cooler. The only way to filter it before the oil cooler is with a relocate kit from BPD or IPR.
Sparky
post #195 of 229 Old 09-27-2018, 04:42 PM
Delos Wood's Avatar
Quoted: 60 Post(s)
Garage
There is no doubt that, that would be far superior to tapping the lines to the degas bottle. Which is what the sinister diesel product does. Got to wait till I get this miss and fuel pressure problem fixed. Then I will order one. I was looking at their website today at lunch.
SparkyF250 likes this.
Delos
2006 F250 King Ranch
2007 Ford Sport Trac
1991 Mustang GT Convertible
Delos Wood is offline
post #196 of 229 Old 09-28-2018, 08:34 AM
roverjosh's Avatar
Quoted: 36 Post(s)
Garage
Ok,
Newbie here. Haven't bought my truck yet. Im just doing the research. MAN there is a lot to worry about...
Ive pretty much settled on a 6.0 because the "problems" seem like they have clear symptoms to look out for which means if your diligent, then you can fix things before they go too far south.
I have a question, I read (can't remember who's ) post that said to do the O-ring process when doing the head gaskets. What is that exactly? Is it literally just replacing every O-ring on the truck at that time or specifically O-rings on the fuel injectors etc because you have the heads out, you might as well kind of thing.
Or are there specifically O-rings on the heads that should be replaced or added? I'm just trying to get my self as "learned up" as I can before I jump in the deep end and buy one of these monsters....
Cheers everyone! Read through the whole Coolant Thread and boy is there a lot of good info in there. Thanks!
Josh
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #197 of 229 Old 09-28-2018, 09:21 AM
Sock Puppet's Avatar
Quoted: 516 Post(s)
Originally Posted by roverjosh View Post
Ok,
Josh
@roverjosh you may want to post up in the general section or use the search function. To answer your question, o-rings on the heads are usually in reference to having grooves cut around the valves on each cylinder. O rings are installed in the grooves prior to cylinder head installation, which compress and provide a better seal when the heads are torqued.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #198 of 229 Old 09-28-2018, 09:31 AM
G8orFord's Avatar
Quoted: 2402 Post(s)
Garage
O-ringed head.
SparkyF250 and voodooridr like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #199 of 229 Old 09-28-2018, 09:35 AM
voodooridr's Avatar
Quoted: 812 Post(s)
Originally Posted by G8orFord View Post
O-ringed head.
Too bad that's gotta be bolted on to an engine, that's pretty
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #200 of 229 Old 09-28-2018, 09:50 AM
G8orFord's Avatar
Garage
It's been bolted on for about 20k now. The head may not be as pretty anymore, but the lack of pressure in the cooling system makes up for it.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
