How long can my truck sit before it needs to run? - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 14 Old 01-20-2017, 04:03 PM
SparkyF250's Avatar
Quoted: 3345 Post(s)
Garage
Originally Posted by WarChild View Post
Actually....That's for a fungus that grows in the Diesel.
"We cannot solve our problems with the same thinking we used when we created them."
Yep, and it can be treated but it's best to keep the water out and not let it grow in the first place. That's why I told the op it's best to keep a full tank in the winter to keep the condensation out, and to use a demulsifying additive
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #12 of 14 Old 01-22-2017, 06:48 AM
GET MY ENEMA BUCKET BRO!!
jacksun's Avatar
Quoted: 151 Post(s)
Originally Posted by HP MACHINE View Post
For long periods of inactivity , pull the FICM relay , crank the motor over a half dozen times to prime the oiling circuits .
Plug the relay back in and it will be ready to go . Combined with everything mentioned above it should be a happy motor !
Wish I'd known about that trick. I let my truck sir a week in the airport parking lot. Got in to start it and the oil temp was 20 degrees per my sct. It fired right up but man what a lope.
Don't you need to be careful with battery tenders. Think my dad was saying he would burn all the water or if his batteries. They need to be on a timer right
coolant-filter-EGR delete-blue spring-ARP's-BPD oil cooler-5in exhaust-horn blasters shocker kit-SCT running SRL++-beans tank sump-BPD water pump-and 4x4 complete
DEUS VULT
jacksun is offline
post #13 of 14 Old 01-22-2017, 07:34 PM
HP MACHINE's Avatar
Quoted: 486 Post(s)
I'm not sure that this would help with the cold lope , but it does get the parts lubed up before starting .
I believe it's good for the lifters and cam more than anything .
HP MACHINE is offline
post #14 of 14 Old 01-23-2017, 03:29 AM
BROWN616's Avatar
Quoted: 20 Post(s)
A quality Battery Tender won't burn the water out of the batteries. I've always used the Battery Tender brand but I've heard of others using other brands with good results. The Batt Tender that I have trickle charges very low and then just maintains. But the one I have would be useless for trying to "charge" the batts from dead or nearly dead, I have an actual charger for that.
My truck also has one heck of a lope on super cold startup until it warms up enough to get to high idle! Then it clears up!
2005 F250SD XL CCSB 4X4
Dark Shadow Gray "The Ghost" LOL
BPD EGR cooler, New Ford Oil Cooler, Scangauge2, Sinister coolant filter.
BROWN616 is offline
