Low boost - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By mudmaster
  • 1 Post By djmaguire
post #1 of 10 Old 12-29-2016, 01:39 PM Thread Starter
Quoted: 5 Post(s)
Low boost
So I have an 03 f250 and I'm not getting boost, so I pulled the turbo and cleaned it all up real good and that still didn't work and so a guy with a real nice scanner scanned it and pulled a P0046 P0402 and a P132B
So I thought it might be related to the VGT solenoid so I got a new one and put it in but it still feels like it's lacking the boost it should be getting
Noahblauert is offline
post #2 of 10 Old 12-29-2016, 04:36 PM
Quoted: 331 Post(s)
Are you able to see what your boost psi is?
Check your CAC boots for cracks and tightness. Also inspect your intercooler as is could have a leak. Didn't check your signature so not sure the year of your truck but if it has the plastic cold side pipe from the intercooler, check for cracks in it too.
jd4010 is offline
post #3 of 10 Old 12-31-2016, 01:27 PM
11427's Avatar
Quoted: 6 Post(s)
Garage
Sounds to me like your EGR valve is sticking or stuck.
Mark
11427 is offline
post #4 of 10 Old 12-31-2016, 04:21 PM
djmaguire's Avatar
Quoted: 1582 Post(s)
Garage
To diagnose the VGT codes, check out the attached presentation. It references 2003.25 MY KA Pinpoint Tests. That and a more general turbo doc are attached, as well.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #5 of 10 Old 01-01-2017, 08:00 AM Thread Starter
Quoted: 5 Post(s)
I took it in to get a test and the dude said he thinks the turbo is bad, he can build 12lbs of boost only I high Rpms when he's gettin on it though and sometimes he can't. Says even though I cleaned it it might not be good enough and that the unison ring my be catching or the fins
post #6 of 10 Old 01-01-2017, 08:04 AM Thread Starter
Quoted: 5 Post(s)
And by the way the EGR Valve I pulled and cleaned so it looked brand new
post #7 of 10 Old 01-02-2017, 10:40 AM
Camshaft350's Avatar
Quoted: 3 Post(s)
Garage
i was told to turn the truck off and pull the egr valve electrical connector and if it solves the problem, then its the culprit! i did and it worked, it isn't sluggish anymore but i still have a terrible exhaust leak on the up pipe so no boost above 8lbs
Camshaft350 is offline
post #8 of 10 Old 01-02-2017, 01:20 PM
Would that throw a p0046 code? My duty cycle is at 84%
Ajsilva is offline
post #9 of 10 Old 01-04-2017, 06:15 AM
mudmaster's Avatar
Quoted: 19 Post(s)
Mine had low boost and it was a blown intercooler. It was hidden and couldn't be seen when installed.
djmaguire and jokester00 like this.
mudmaster is offline
post #10 of 10 Old 01-04-2017, 06:41 AM
djmaguire's Avatar
Garage
To find leaks in the intercooler system, you can get one of these at the hardware store:
...glue a Schrader valve into it, connect it to the turbo where your CAI attaches, and charge it up with an air compressor.
TurboSpin likes this.
2004 F550 CC Lariat
