Alternative water pump 6.0 - Ford Powerstroke Diesel Forum
 51Likes
post #1 of 52 Old 11-20-2016, 06:35 AM Thread Starter
Quoted: 7 Post(s)
I have found a new water pump with a metal impeller not plastic for almost half the price of the Alliant AP63503. It is the ACDELCO 252-885 Professional Water Pump. Good quality pump that won't cost a arm & a leg.
ACDELCO 252-885 04.5-07
ACDELCO 252-886 03-04
jjohnsonlta is offline
post #2 of 52 Old 11-20-2016, 07:00 AM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1738 Post(s)
Feedback Score: 6 reviews
Other than a metal impeller, what makes it a good upgrade?
ZMANN and mhatlen like this.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 52 Old 11-20-2016, 07:14 AM
ZMANN's Avatar
Quoted: 3934 Post(s)
here is a pic of a ACDELCO 252-885 04.5-07
good chance you are in for a crap shoot on what you get impeller wise with the low bidder of the day to AC-Delco
Rattlesnake18 and mhatlen like this.
6.0 flush pdf
ZMANN is offline
post #4 of 52 Old 11-20-2016, 07:16 AM
ZMANN's Avatar
here is the ACDELCO 252-886 03-04
6.0 flush pdf
ZMANN is offline
post #5 of 52 Old 11-20-2016, 07:49 AM Thread Starter
Quoted: 7 Post(s)
This pump is described as a premium aftermarket replacement pump. The fact that it comes with the metal impeller a plus. I would guess it would last about same as factory pump. It's up to you on what you buy and I am just giving info on another option available that I found. The impeller looks more like factory design than Alliant does.
post #6 of 52 Old 11-20-2016, 08:30 AM
wellcraft's Avatar
Quoted: 118 Post(s)
That looks like a plastic impeller, you can even see the impression from the injection molding.
wellcraft is offline
post #7 of 52 Old 11-20-2016, 09:03 AM
ZMANN's Avatar
Agreed
the pictures I found of the AC delco units are injection molded media ( plastic) beyond a shadow of a doubt
you can't make metal take that shape without casting or billet steel
and it would be to heavy and cost much more
thats why BPD uses CNC machined billet aluminum
any metal ( steel) impeller 6.0 pumps I have seen are the traditional stamped steel design
6.0 flush pdf
ZMANN is offline
post #8 of 52 Old 11-20-2016, 09:13 AM
ZMANN's Avatar
if i wanted metal and didn't want to pay for a BPD quality, rebuild able unit ( to late already did lol)
i would drop 120.00 on a lifetime warranty from Dieselsite unless i could find a similar unit from our sponsors
6.0 flush pdf
ZMANN is offline
post #9 of 52 Old 11-20-2016, 09:24 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
When I had my engine work done I opted to replace my Waterpump because the truck was pulled apart at the time. Only one option in my book on something as vital as the Waterpump. BPD and it has to be black so it matches the paint on our engines. What paint they managed to spray on it. Cheap bastards.
darkpassenger likes this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #10 of 52 Old 11-20-2016, 11:32 AM
GregsSD's Avatar
Quoted: 18 Post(s)
Garage
I put a BPD water pump on mine while I had the engine apart. I am very glad that I did because when I pulled off the original pump, I found a crack on the center of the impeller (where it slides onto the shaft).
Now I know I won't have to worry about it again!!!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
