Delta ? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-18-2016, 09:27 AM Thread Starter
Delta ?
I was checking my deltas on my new to me f250, it's been bone stock it's whole life and has 186,000 on it now. I was towing my boat that's about 4500 fully loaded at 65-70mph my deltas went up to 19deg but would come back down to 12-14 range my question is should they never go over 15 or is it ok to go over then come back down
robrat20 is offline
post #2 of 17 Old 11-18-2016, 09:32 AM
K9Gunner's Avatar
Quoted: 30 Post(s)
If the truck was not completely warmed up it will go well past 15*. Sounds like your truck warmed up and they came back down to me.
2003 Ford F-350 6.0 Lariat. Edge Insight Pro CTS 2. Bone stock.
K9Gunner is offline
post #3 of 17 Old 11-18-2016, 09:41 AM
johnnybgood's Avatar
Quoted: 110 Post(s)
The 15 degree delta should be checked when driving unloaded, around 2000 rpms, on flat ground, for a decent amount of time, at fully warmed up temp.
Even still, i wouldn't be happy seeing a 19* difference in temps towing my boat(8300 loaded).
2005 Excursion Limited w/274K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -EGR delete -Torque Pro App
johnnybgood is offline
post #4 of 17 Old 11-18-2016, 09:43 AM
G8orFord's Avatar
Quoted: 2591 Post(s)
Garage
The test should be done unloaded, not towing, at ~65mph (~1900 RPM) on reasonably flat roads after reaching operating temp. Observe the temps for 10-20 minutes and average out the numbers (though they should stay fairly consistent).
19° towing that light would probably be a cause to check more accurately while not towing, per the above instructions.
@K9Gunner mentioned that the delta might go past 15° as the engine warms up, but that is of no concern. First, that would be a negative delta. Meaning that the coolant was actually warmer than the oil which is not a problem at all while warming up. The number you are worried about is how much warmer the oil gets over the coolant temp after operating temp.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #5 of 17 Old 11-18-2016, 09:53 AM Thread Starter
Ok well my drive to work is a hr plus been monitoring the last few weeks I never get more than 7deg difference
robrat20 is offline
post #6 of 17 Old 11-18-2016, 09:56 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
Sounds like you need to check your wheel bearings, tires, and brakes on that trailer.
Either that, or your 65-70 was really 75-80 uphill.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is online now
post #7 of 17 Old 11-18-2016, 09:58 AM Thread Starter
Delta ?
Trailer is good rebuilt last year, the speedo might be off and I live in the south so not to many hills here
robrat20 is offline
post #8 of 17 Old 11-18-2016, 10:01 AM
Heavy_GD's Avatar
Garage
Well, as long as the fan is working on your truck and the fluid is topped off... drive on driver.
GD
post #9 of 17 Old 11-18-2016, 10:04 AM Thread Starter
Delta ?
I didn't pay to much for the truck trying see if I should replace the oil cooler and do a EGR delete to it or just wait till a get a head gasket issue. I already did a 4" straight pipe
I have 8700$ in the truck
robrat20 is offline
post #10 of 17 Old 11-18-2016, 11:03 AM
Quoted: 110 Post(s)
If it aint broke...
EGR leaking? Coolant spitting? White smoke? Running hot(temps never stated)? If not, as Heavy said, drive on.
