Which oil?????????? - Page 2 - Ford Powerstroke Diesel Forum
 34Likes
post #11 of 30 Old 11-20-2016, 03:23 PM
Deer Creek's Avatar
Quoted: 71 Post(s)
Originally Posted by Master_Chase View Post
Over 100K don't switch because if you do the synthetic particles will split the atoms of the dino and basically you will have an atomic bomb go off.
JK you can switch back and forth whenever you want doesn't matter how many miles. If it makes you feel better I switched over to synthetic at 185K ish
Hahahahaha! Same here I switched over to T6 at 200k
mr.travo and john galt like this.
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #12 of 30 Old 11-20-2016, 03:26 PM
mr.travo's Avatar
Quoted: 16 Post(s)
LOL! I appreciate it! Looks like my next oil change will be switching to 5-40 T6. I've always been a Rotella fan.
2005 F250 Lariat CC LB 4x4
205K miles
- EGR deleted
- Muffler deleted
- Metal CAC intake tube
- Riff Raff turbo boots
- B&W gooseneck hitch
- Peacemaker front bumper
- Blue spring kit
Best $10,000 truck I ever bought!!!
mr.travo is offline
post #13 of 30 Old 11-20-2016, 04:00 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1683 Post(s)
Garage
Yea that's what these trucks like. I've used 5W/40 forever in two trucks and both ran like a clock. It's fabulous oil and light years ahead of natural oil.
Like everyone says go with the jug that looks prettiest to you. Rotella is very popular and I think it's because Wal Mart has had it on the shelf cheap for years. I'm no different but probably use Delo more often. The biggie in brands is important on the filters go Motorcraft ONLY.
Have fun with it and look at the beer you can buy now instead of blowing the cash all on crazy costly oil.
zsargent, john galt and K9Gunner like this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #14 of 30 Old 11-22-2016, 06:02 AM Thread Starter
K9Gunner's Avatar
Quoted: 28 Post(s)
Thanks for all of the responses. I have enough Amsoil for two more oil changes so after I run out I will let you know what I decide to do. Keep the input coming . Thanks
2003 Ford F-350 6.0 Lariat. Edge Insight Pro CTS 2. Bone stock.
K9Gunner is offline
post #15 of 30 Old 11-22-2016, 06:11 AM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 568 Post(s)
I use amsoils biggest rival, RP, and I go 10k between changes. I also use archoil every change. 250.00 a oil change, but at 70 every 3k for dino, worth it.
john galt likes this.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #16 of 30 Old 11-23-2016, 10:26 PM
Quoted: 5 Post(s)
Originally Posted by mr.travo View Post
Being that I have 200K miles, would switching over to a synthetic oil hurt? I always heard that you don't switch after 100K-ish miles.
Thanks!
Sent from my iPad using Tapatalk
on my 7.3 I switched at 270k miles... engine has never been apart and on the original injectors. Still runs great.
Richard
DarkStar is offline
post #17 of 30 Old 11-23-2016, 10:33 PM
It is What IT is
Quoted: 436 Post(s)
Thanks!
that's a total myth and a bunch of bs.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #18 of 30 Old 11-23-2016, 10:34 PM
It is What IT is
Quoted: 436 Post(s)
What he says but my truck doesn't like Delo (neither did my last one)....
Zach
168,084 miles....
zsargent is offline
post #19 of 30 Old 11-28-2016, 10:00 AM
Quoted: 3 Post(s)
Speaking from experience, a higher mileage engine may have some sludge buildup, and in my case I put Mobil One in an engine with 160k. The synthetics have more cleaning additive and will loosen whatever sludge you may have and clog the pickup filter in the pan. To fix that problem I changed oil 3 times with a thinner oil, then put good oil back in. It worked. you an always drop the pan and clean it. That's the best method.
Patriotic Conservative Veteran
john767 is offline
post #20 of 30 Old 11-29-2016, 12:19 AM
It is What IT is
Quoted: 436 Post(s)
I'm not aware of a pan filter in the 7.3 or 6.0. Plus dropping the pan on either one is not exactly easy. Now if you're talking transmission, then yes there's a filter in the pan and that's easily dropped.
Am I missing something here ? I thought we were talking ENGINE oil not tranny...
and what's "good oil"?
Zach
168,084 miles....
zsargent is offline
