Amsoil Coolant - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 20 Old 11-10-2016, 12:01 PM
ZMANN's Avatar
Quoted: 3884 Post(s)
the Caterpillar brand CAT ELC EC1 i run is 25 bucks a gallon
but in concentrate form you buy a gallon of distilled
and now you have two gallons of premix for 13$ each
their concentrate is like 20 bucks
ea so def worth the effort to mix
6.0 flush pdf
ZMANN is offline
post #12 of 20 Old 11-10-2016, 12:53 PM
JustinOOO9's Avatar
Quoted: 1518 Post(s)
Garage
Feedback Score: 3 reviews
zerex and rotella make the cat elc stuff too. you can often find the zerex at NAPA for under $18 a gallon of concentrate or I found rotella for 14.95 a gallon of concentrate.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #13 of 20 Old 11-10-2016, 01:02 PM
ZMANN's Avatar
they make cat ec1 rated stuff not the CAT stuff ;-)
i prefer to buy from the folks that set the standard that others have to meet
that and being in AZ we have a lot of mines so Caterpillar places like Empire Machinery are close to me
onealmx11 likes this.
6.0 flush pdf
ZMANN is offline
post #14 of 20 Old 11-10-2016, 01:10 PM
JustinOOO9's Avatar
Garage
fair enough. If it makes anyone feel better some inlaws were asking about it for their big rigs because the cat e5 stuff was on the list from the owners manual. 400k later hes changing the rotella stuff and looks just a little darker.
I would love to buy from cat and I worked for one of their dealerships as a Low boy driver delivering for the earth mover division, but I don't and there went the discounts hahaha.
ZMANN likes this.
Justin
post #15 of 20 Old 11-10-2016, 01:43 PM
1fastsvt0816's Avatar
Quoted: 9 Post(s)
My vote goes to Zerex Cat etc. It can be bought locally at Napa or you can get it on Amazon. It's full concentrate so essentially you get 2 gallons out of it. Part number at Napa is ZXED1
https://www.amazon.com/Zerex-ZXED1-E.../dp/B0033QVL9C
1fastsvt0816 is offline
post #16 of 20 Old 11-10-2016, 05:01 PM
Baddestt's Avatar
Quoted: 9 Post(s)
We use Delo ELC. Just outstanding coolant. Easy to get off Amazon as well:
https://www.amazon.com/Delo-22781149...XYECMKFPT9N618
They have the 50/50 and full concentrate
Amsoil is best on ATF and Gear oils
Baddestt is offline
post #17 of 20 Old 11-10-2016, 05:36 PM
Quoted: 40 Post(s)
Originally Posted by K9Gunner View Post
ShiZor9, how many gallons does it take since it is already 50/50 mix?
Buy 4 gallons, after flushing you put those in followed by distilled til you hit the minimum on the degas bottle.
ShiZor9 is offline
post #18 of 20 Old 11-13-2016, 01:27 PM
Quoted: 331 Post(s)
Doing this will get you less than a 50/50 mixture since the system does not fully drain. I suggest only using the premix to top off when needed but not at a fresh fill. For a fresh fill, after flushing with distilled water, put in 14 quarts of concentrate then top off with distilled.
jd4010 is offline
post #19 of 20 Old 11-13-2016, 01:57 PM
Baddestt's Avatar
Quoted: 9 Post(s)
Per my Master Ford diesel tech, doing what you describe is not for the best cooling efficiency in hot climates for a "fresh fill" in mostly southern states (southern ca, Texas, Arizona, Louisiana, fl etc). However it would be for Midwest/northern states (including Utah, Montana ID, CO etc) where your much more likely to endure sub zero overnight temps. 50/50 pre-mix on a fresh fill is best in the south.
I'm sure there are a lot of opinions on this, but I've been using 50/50 pre-mix Delo ELC. No issues.
Baddestt is offline
post #20 of 20 Old 11-13-2016, 02:33 PM
ZMANN's Avatar
point being after doing a cooling system flush and finishing with pure distilled
you have a few gallons of water left in the system
using the concentrate gets you close to 50/50 if you add 50/50 your ratio is very low and 50/50 is as low as they recommend in most cases
pretty sure Shizor9 missed the 50/50 part and was thinking concentrate ?
jd4010 likes this.
6.0 flush pdf
ZMANN is offline
