Code 1032 Low Battery from SCT Livewire - Ford Powerstroke Diesel Forum
post #1 of 32 Old 10-06-2016, 10:02 AM Thread Starter
Deer Creek's Avatar
Quoted: 66 Post(s)
I will try posting here and see if I can get some help;
Ok so all the work is done to the truck. Downloading the Tune from the SCT Livewire and it shows the progress bar. It gets all the way to 99% complete then says Code 1032 Low Battery. Any ideas what this is and how do I fix it?
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #2 of 32 Old 10-06-2016, 10:08 AM Thread Starter
Deer Creek's Avatar
Quoted: 66 Post(s)
So the tech at the shop is thinking that maybe the OTHER shop never returned it to stock so he tried that and the tuner gives the same 1032 code Low Battery then says push wheel to continue and then it pops up code 1027 incorrect vehicle.
What's that?
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #3 of 32 Old 10-06-2016, 10:16 AM
G8orFord's Avatar
Quoted: 2513 Post(s)
Garage
Maybe put a battery charger on your truck?
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #4 of 32 Old 10-06-2016, 10:17 AM
Quoted: 40 Post(s)
Can you see if the tuner is still married?
I'm still unsure as why a shop would return it to stock unless you or they explicitly said it would be done.
I've seen custom tunes lost, or needing SCT to unlock it because of a bad PCM.
ShiZor9 is offline
post #5 of 32 Old 10-06-2016, 10:25 AM Thread Starter
Deer Creek's Avatar
Quoted: 66 Post(s)
No it says NOT married. What do I do now?
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #6 of 32 Old 10-06-2016, 10:32 AM
Quoted: 40 Post(s)
Not married means it was returned to stock.
Can you verify the strategy of the truck vs. What your tunes are custom made to. Or are these out of the box tunes included with the SCT?
ShiZor9 is offline
post #7 of 32 Old 10-06-2016, 10:34 AM Thread Starter
Deer Creek's Avatar
Quoted: 66 Post(s)
No they are custom tunes. I had Charlie at KC Turbos get them for me. I remember we had to verify strategy code.
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #8 of 32 Old 10-06-2016, 10:43 AM
Quoted: 40 Post(s)
Does the truck start as it sits?
If yes, plug in the SCT and see if you can pull up the strategy to see if it was the one Charlie wrote for you.
It also may need some sort of an update from SCT too, so consider calling their tech support.
ShiZor9 is offline
post #9 of 32 Old 10-06-2016, 10:49 AM Thread Starter
Deer Creek's Avatar
Quoted: 66 Post(s)
Will do. Yes we tried to call SCT support first but because they are in Florida they are closed until Monday due to the hurricane.
What's crazy is I trust the info I get from the ORG more than I would from anywhere else.
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #10 of 32 Old 10-06-2016, 11:03 AM
Heavy_GD's Avatar
Quoted: 3099 Post(s)
Garage
Feedback Score: 4 reviews
Most of us do...
Maybe try the battery charger idea from above
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
