oil flush? - Ford Powerstroke Diesel Forum
 31Likes
post #1 of 43 Old 05-20-2016, 12:38 PM Thread Starter
saleen9973's Avatar
Quoted: 46 Post(s)
oil flush?
Hey guys I got my hands on some BG products engine performance restore. Its a engine flush. I read you can use it on diesels and it cleans everything out. Breaks up carbon and deposits. then change oil. Should I do it?
darkpassenger likes this.
saleen9973 is offline
post #2 of 43 Old 05-20-2016, 12:41 PM
7.3lf550's Avatar
Quoted: 68 Post(s)
Dont fix it if it aint broke!
john galt likes this.
7.3lf550 is offline
post #3 of 43 Old 05-20-2016, 12:45 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1871 Post(s)
Garage
I'd just change the oil and add archoil. As @7.3lf550 said, don't fix it if it ain't broke! You might just create a headache for yourself.
Justin
2005 F250 FX4 Lariat 292k
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Powermax USA 250 amp Alt - Custom Big 3 Upgrade -
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
The Following User Says Thank You to waggonerj For This Useful Post:
Qholic (05-20-2016)
post #4 of 43 Old 05-20-2016, 12:56 PM
7.3lf550's Avatar
Quoted: 68 Post(s)
I second the archoil.
7.3lf550 is offline
post #5 of 43 Old 05-20-2016, 02:01 PM
6.0 Powerstroke n00b
krazyk's Avatar
Quoted: 123 Post(s)
Garage
or RevX and your good to go. Anything else will destroy a 6.0 PSD.
JesseKK and darkpassenger like this.
2006 6.0 F250 FX4
krazyk is offline
post #6 of 43 Old 05-20-2016, 02:44 PM
ChrisSki's Avatar
Quoted: 552 Post(s)
I don't like to be the first kid on the block to try something.
One of the things about the 6.0, is you don't pull enough oil out during an oil change to make the oil lighter it always remains black. I think about 1/8 the oil or about a half gallon stays in the system. One quart is in the High Pressure oil reservoir that doesn't drain, than the rest of the oil is in the rails and the HPOP.
So, you never really get anything you add to the oil out. 1/8 of the additive you put in there will still be in afterwards, so unless it's made to run through the engine constantly, then you probably shouldn't add it.
Also, if it does break up carbon deposits, then these liquid cooled filters have small passages that are located prior to the oil filter, so the cooler actually pre-filters anything going to the filter; however, it is the coolant passages that tend to clog up the cooler and not the oil passages.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
post #7 of 43 Old 05-20-2016, 05:04 PM Thread Starter
saleen9973's Avatar
Quoted: 46 Post(s)
Well it seems that I shouldn't do the flush. The directions on the can say put in oil, run engine at 1200rpm for 10 minutes then drain and fill with new oil and put new filter on. It is a solvent so some of will stay in the oil system because of the hpop. I got it for free so no loss to me.
post #8 of 43 Old 05-20-2016, 05:26 PM
beanoil's Avatar
Quoted: 55 Post(s)
Garage
Ummmmm... Proof?
A list perhaps of products you have experience with that destroyed a 6.0?
beanoil is offline
post #9 of 43 Old 05-20-2016, 05:30 PM Thread Starter
saleen9973's Avatar
Quoted: 46 Post(s)
Say goodbye to diesel woes
November 6, 2007
When most people think of diesels, they’re reminded of smoke belching semis, smelly city buses or noisy, poorly engineered passenger vehicles. These perceptions represent actual disadvantages of yesterday’s diesel engine.
In 2002, International Trucks created the 6.0 Ford Powerstroke engine with hydraulic injectors. It built a reputation as one of the most powerful performers in the light-duty diesel market, plus it’s quiet and clean! Unfortunately, the Ford 6.0 Powerstroke is highly susceptible to carbon deposits in its EGR and air intake system. In less than 20,000 miles, carbon build-up has the potential to completely plug the EGR.
In addition, the high soot content of the diesel engine oil plugs the oil passages causing the injector to misfire. This aggravates existing driveability problems of rough idling, hard starting and poor fuel economy.
Until now, the only way to clean the exhaust and fresh air passages was to physically remove the engine components and have them steam-cleaned. This process is costly and inconvenient and, as a result, rarely performed.
Unparalleled by any other diesel service, the BG Diesel Induction Service chemically cleans each component and completely restores the vehicle to peak performance…without engine tear down! This service moves BG Diesel ISC® Induction System Cleaner,™ PN 25532, through the EGR runners and cavities as well as the air intake. BG EPR® Engine Performance Restoration, PN 10932, is added to the engine oil while the induction service is being performed to clear the oil passages of the hydraulic injectors and restore performance.
The EGR valve is thoroughly cleaned with BG Throttle Body and Intake Cleaner, PN 406.
9255product2
taken from BGsite
post #10 of 43 Old 05-20-2016, 05:42 PM Thread Starter
saleen9973's Avatar
Quoted: 46 Post(s)
Got this from diesel bombers. Guy was wasting injectors someone posted this.Well Injector Failures wont really be fixed by going to a larger nozzle. It may even make the problem worse. If your having problems with a 6.0 you need to start by looking at the oil change pattern , what oil and so on. BG Products does a oil system flush thats been known to help! What symptoms are you having and we'll be able to help you a little more!
