FUEL PSI GAUGE - Page 3 - Ford Powerstroke Diesel Forum
 7Likes
post #21 of 24 Old 03-13-2016, 05:28 PM
Mitch
thebierguy's Avatar
Quoted: 110 Post(s)
I went with the Autometer electric fuel gauge. Then bought the strictly diesel fuel pressure hose and adapter to get the sensor away from the engine. So far happy with the set up. Have noticed through the winter that when everything is closed, I get a jumpy gauge. Once it warms up, the gauge is a steady 62-64 psi.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #22 of 24 Old 03-13-2016, 05:34 PM
'consent of the governed'
Patriot's Avatar
Quoted: 2215 Post(s)
Garage
Isspro 2!!!
Patriot is offline
post #23 of 24 Old 03-24-2016, 04:52 PM
Mo Diesel sir!
sleepy steve's Avatar
Quoted: 55 Post(s)
where does it mount to? do you have pics of this installed? this is what ive been looking for but not sure where it all hooks up to and i read that it doesnt come with instructions...thanks
2003 F350 6.0 CCSB 4x4
3.5" lift with 17" MT Classic II 35x12.50/17Terra Grappler G2
4" MBRP turbo back cat delete, ARP studs,
SCT Tunes from PHP & WPE, Bullet Proof EGR cooler,
HID heads and fogs, 08+ tailgate/tails/mirrors,
LED bars and pods, FICM from Ed, Blue Spring
DC Power 270 alternator, Mishimoto intake elbow,
Mishimoto Coolant Filter, Scan Gauge II,
A-pillar gauges (Boost, EGT, Fuel pres.),
Air Compressor for Sh**s and giggles
for life!
sleepy steve is offline
post #24 of 24 Old 03-27-2016, 06:01 PM
Mitch
thebierguy's Avatar
Quoted: 110 Post(s)
The adapter mounts to the fuel bowl, and it has the right threads to mount to the fuel bowl. I just put some Teflon tape on the threads and threaded it in. It fit perfect so I did not need to remove the cover for the fuel pressure spring, although this is a good time to do the blue spring mod. Then I ran the hose from the fuel bowl towards the drivers side, under the rad hose, between the battery and drivers side head, then it terminated just behind the drivers side battery. That is where I hooked up the sending unit. I can grab some pictures tomorrow.
Sent from my SM-N920V using Tapatalk
Mitch
