Remote vs OEM oil filter with BPD oil cooler kit? - Page 21 - Ford Powerstroke Diesel Forum
 78Likes
post #201 of 203 Old 12-09-2015, 08:52 PM
j.flow's Avatar
Quoted: 4251 Post(s)
Originally Posted by portcity_gt View Post
Ill have to measure the length of my lines.....they were just some leftover nitrous lines i had lol.
And the bracket is just a piece of aluminum angle i cut and drilled to shape.
I'll just order like 6ft. Should be plenty
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
post #202 of 203 Old 12-28-2015, 01:35 PM
2sunf350's Avatar
I got this for Christmas took 10 min to put on I had to move antifreeze filter over a little but no big deal.
(B)Ford 6.0 Powerstroke (2003-2007) black kit (ocspsbf 6.0 black) | Oil Charge Systems
2sunf350 is offline
post #203 of 203 Old 10-07-2016, 10:51 AM
Baddestt's Avatar
Quoted: 9 Post(s)
Wow. Good read. I had this same dilemma before I ultimately decided to go with the BPD HD oil cooler withOEM oil filter. Although, I'm familiar with he few drawbacks, I feel the OEM set up/filtration will work best for me. I get my kit tomorrow via FedEx and super excited to get it installed
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, KC Stage 1.5 Turbo, SCT SF3 tuner, F-Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, Amsoil Gear lube, Delvac 1 ESP 5w30, Delo ELC, bpd ficm, BPD HD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
