Loud Injector Buzz and High Pitched Hum after blue spring? (VIDEO) - Ford Powerstroke Diesel Forum
 47Likes
post #1 of 94 Old 11-10-2015, 06:24 AM Thread Starter
Quoted: 16 Post(s)
HELP! Loud Injector Buzz and High Pitched Hum (VIDEO)
Just got my truck back after bulletproofing and I noticed the injector buzz is way louder, and there is a high pitched hum at the end of fuel prime. Like a dying goat.
My tech says it's normal, but it's really, really odd....
Fresh heads, gaskets, studs
Standpipes, injector seals and orings
Blue Spring upgrade
new ICP/harness
new IPR screen
a ton of other updates
https://youtu.be/dw1Hcu9XDwg
rman is offline
post #2 of 94 Old 11-10-2015, 07:53 AM
djmaguire's Avatar
Quoted: 1587 Post(s)
Garage
Originally Posted by rman View Post
... Like a dying goat. ...
I'm thinkin', "Yeah. Like a dying goat. What's a dying goat even sound like?!"
Dang. That sounds exactly like a dying goat. ...and I'm not agreeing with your mechanic as to it being normal. Following this to learn more
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #3 of 94 Old 11-10-2015, 07:55 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Most likely the installer MISSED the o-ring that goes on the plastic cup that holds the brass fitting the spring goes in. On the 04+ trucks there is a oring that goes behind/on the black plastic piece. Without it, there is a pressure leak and that noise.
TurboMustang370 and djmaguire like this.
toren302 is offline
post #4 of 94 Old 11-10-2015, 08:02 AM Thread Starter
Quoted: 16 Post(s)
mines an 03?
rman is offline
post #5 of 94 Old 11-10-2015, 08:03 AM Thread Starter
Quoted: 16 Post(s)
what about that rythmic tapping afyer the injector buzz?
rman is offline
post #6 of 94 Old 11-10-2015, 08:52 AM
Heavy_GD's Avatar
Quoted: 3140 Post(s)
Garage
Feedback Score: 4 reviews
goats lives matter.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #7 of 94 Old 11-10-2015, 08:56 AM
It is What IT is
Quoted: 433 Post(s)
not normal at all......
Greg,
are you talking about white goats or black goats lives???
Heavy_GD and 2003SuperDuty like this.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #8 of 94 Old 11-10-2015, 08:57 AM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 568 Post(s)
Originally Posted by Heavy_GD View Post
goats lives matter.
I cannot express my sheer pride and joy that you left the pound sign off that post.(I will never call it by the name that my daughter will know it as again. Pound signs lives matter too.)
ZMANN likes this.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #9 of 94 Old 11-10-2015, 09:02 AM
djmaguire's Avatar
Garage
@ZMANN is going to great lengths to further your cause. From another thread...
Originally Posted by ZMANN View Post
your welcome
ZMANN, zsargent and starcommtrey1 like this.
2004 F550 CC Lariat
post #10 of 94 Old 11-10-2015, 10:10 AM Thread Starter
Quoted: 16 Post(s)
anyone know if there is an oring issue with the 03?
rman is offline
