EGR Delete this weekend: Coolant Flush? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-09-2015, 08:08 AM Thread Starter
MTBSully's Avatar
Quoted: 9 Post(s)
Picked up a 2006 Harley F350 last week, bone stock with 100k miles. Shes cherry! Either way I have already ordered EGR delete, 5" exhaust, SCT tuner with tunes from Quick Tricks, and will be doing a Rotella T6 oil change with Motorcraft filter this weekend. I noticed when installing the EGR delete it says to drain all coolant. Do you guys do this from the radiator? Is this a good time to flush it all out and do CAT ELC? I don't want to clog up my oil cooler doing this. Does anyone have any suggestions, tips or a coolant flush procedure?
MTBSully is offline
post #2 of 3 Old 11-09-2015, 08:29 AM
6.0 Powerstroke n00b
krazyk's Avatar
Quoted: 123 Post(s)
Garage
I also have a 2006. JMO but while I had mine that far down I did the oil cooler update and some other 6.0 fixes while I was there. Its a good time to do a complete coolant flush as well. Instead of the Cat coolant I went with the latest N&I(according to Ford) Ford Gold coolant but I'm also in a very mild climate.
I know there is much debate about this but while I had my engine apart, I saw no indications of any types of failure. I just changed everything as PM. Guess I was one of the lucky ones.
2006 6.0 F250 FX4
krazyk is offline
post #3 of 3 Old 11-09-2015, 08:51 AM
Weberman3's Avatar
Quoted: 645 Post(s)
Send a message via MSN to Weberman3
If you're planning on switching coolant eventually, then I would go ahead and start flushing now. When I flushed mine, I just used a water hose to make it run clear. Then I ran distilled water through 5 times. I didn't use any chemicals during the flush, I was just making sure that I got all of the green coolant out when the previous owner studded and deleted it
2004 F350 XLT 6.0L ZF6 CCSB
ARP Head Studs, EGR Delete, 4" Turboback, Fuel Sump, Coolant Filter, NUC Oil Bypass Filter
Kenwood DDX372BT with Rear View Camera, Rockford Fosgate P1683 speakers, Infinity REF1200 subwoofers
Weberman3 is offline
