Big air bubble in coolant system? - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 15 Old 11-08-2015, 02:57 PM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
Originally Posted by Kevinx View Post
Am I the only one that feels the athe OP is incredibly lucky to not have scalded himself. The do not open hot on the cap is no joke. That cap should have hissEd for a solid couple minutes to relieve pressure.
He was lucky, yes. I was guessing that he knows that he was lucky. ...and that anyone else reading this would know it, as well.
I got hit with coolant from my block drain during my ELC swap because I was rushing things. It slowed me back down real quick.
Rattlesnake18 likes this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #12 of 15 Old 11-08-2015, 03:13 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1738 Post(s)
Feedback Score: 6 reviews
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Drive it for a bit. Let it cool. Release the pressure. Add coolant if necessary. Drive it more. Hard. Let it cool. Repeat as needed.
...and, for heaven's sake, don't ever do what you did again (without videotaping).
Great post. I'm going to use part of it as my new sig quote.
Same thing happened to me. During one of my drains I had a tube connected to the nipple of the Fumoto valve, when I opened the valve the tube came off and hot distilled water started pouring out everywhere and got on me. I rolled out from under the truck as fast as I could, took a few deep breathes, and told myslef "Let's not let that happen again."
djmaguire likes this.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Rattlesnake18 is offline
post #13 of 15 Old 11-08-2015, 03:19 PM
djmaguire's Avatar
Garage
Originally Posted by Rattlesnake18 View Post
... Same thing happened to me. During one of my drains I had a tube connected to the nipple of the Fumoto valve, when I opened the valve the tube came off and hot distilled water started pouring out everywhere and got on me. I rolled out from under the truck as fast as I could, took a few deep breathes, and told myslef "Let's not let that happen again."
Exactly. It's like we were using the same playbook.
2004 F550 CC Lariat
post #14 of 15 Old 11-08-2015, 03:49 PM Thread Starter
Master_Chase's Avatar
Quoted: 517 Post(s)
I will say this I wasn't worried about anything coming out because I couldn't see a coolant line (I wish these things were clear) when it popped off some did get on me but to my surprise it didn't burn like what I thought 200F would. A lot more would have gotten on me if I didn't have the sound insulation that diverted it forward and to the passenger side.
After more than 2 hours of sitting I went to top it off and when I undid the cap almost all the coolant in the reservoir drained out so the bubble is starting to work its way out. Also my upper radiator hose sounds like it has some air in it well.... I have a new project for tomorrow now.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #15 of 15 Old 11-09-2015, 08:18 AM
6.0 Powerstroke n00b
krazyk's Avatar
Quoted: 123 Post(s)
Garage
To the OP: If you want to do another coolant system repair/flush/refill and don't want to have lifelong scars from 3rd degree burns, get a Uview Airlift system. Works amazingly well and is worth the money. Glad you weren't injured.
krazyk is offline
