Losing boost while towing - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-08-2015, 12:39 PM Thread Starter
Gui272's Avatar
Quoted: 2 Post(s)
Hello,
So yesterday I was towing an empty trailer. It weighs roughly 3,000 lbs. On flat ground it was fine and up to about 19psi. Once I went over 20 psi it would run for a little then drop down to 15 ish psi and lose power.
Egt,oil temp,coolant temp,ficm all good according to my cts when it was hhapening.
Truck has egr delete, new cold side turbo tube, upgraded boots and clamps on boots.
Was running 65 hp tow tune on my x4.
Where do I start? It seems every time I tow anything I have problems. It's getting old!!
Gui272 is offline
post #2 of 6 Old 11-08-2015, 12:41 PM Thread Starter
Gui272's Avatar
Quoted: 2 Post(s)
Truck also had entire coolant system flushed and oil cooler replaced. Differential is roughly 6 degrees while towing.
Gui272 is offline
post #3 of 6 Old 11-08-2015, 02:34 PM
peixinho's Avatar
Quoted: 344 Post(s)
monitor your boost, ebp, vgt, and maf to see if anything weird is going on.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 6 Old 11-08-2015, 02:59 PM
Ez
Quoted: 23 Post(s)
Garage
double check your boots
2003 6.0
SoBStevens is offline
post #5 of 6 Old 11-09-2015, 06:23 AM Thread Starter
Gui272's Avatar
Quoted: 2 Post(s)
What kind of numbers should I see?
Gui272 is offline
post #6 of 6 Old 11-09-2015, 06:24 AM Thread Starter
Gui272's Avatar
Quoted: 2 Post(s)
What's EBP???
Gui272 is offline
