Oil Analysis - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-04-2015, 06:09 PM Thread Starter
Diesel DB
USAF93's Avatar
Quoted: 113 Post(s)
Garage
Oil Analysis
I got my first oil analysis back from Blackstone. I think it looks good. They say the iron results are really good. Does anyone know how I can make heads or tails of the report? I thought they would explain more.
I've got a 2005 F350 with 132,500 miles. I've attached the report. Thanks!
USAF93 is offline
post #2 of 10 Old 11-04-2015, 07:22 PM
Quoted: 2 Post(s)
Don't see the report attached. I live in Hampton also btw.
nismofan240 is offline
post #3 of 10 Old 11-05-2015, 02:36 AM Thread Starter
Diesel DB
USAF93's Avatar
Quoted: 113 Post(s)
Garage
Sorry, right after I posted it I remembered/realized that my full name, address, phone number and email address was on the top. Can't be havin that kinda info posted! I'm going to print a copy with that info covered and post an update. Great to know someone else from Hampton is on here! I'm in the Willowoaks area of Hampton.
USAF93 is offline
post #4 of 10 Old 11-05-2015, 04:02 AM
ZMANN's Avatar
Quoted: 3899 Post(s)
lots of people post the reports you black out the name and addy or chop it all off and then post
ZMANN is offline
post #5 of 10 Old 11-05-2015, 03:19 PM Thread Starter
Diesel DB
USAF93's Avatar
Quoted: 113 Post(s)
Garage
I wasn't able to print last night so I used my work adobe to edit. Now it should be attached. Sorry about that.
USAF93 is offline
post #6 of 10 Old 11-05-2015, 04:11 PM
Quoted: 300 Post(s)
At the bottom of the range, but still a 40wt after 5k miles. Very nice results. I really like the TDT oil.
bismic is online now
post #7 of 10 Old 11-05-2015, 04:23 PM
Quoted: 11 Post(s)
They basically look for any signs of bearing wear (zinc, copper iirc), piston/wall contact (iron), etc. They also look for signs of coolant leaks (water or antifreeze %), fuel not getting burnt or leaking , etc. He's basically just saying that the report doesn't show any signs of problems. Thats what you want to see!
The averages on the right are for your engine type so you can get a good idea of how you stack up.
yinzer is offline
post #8 of 10 Old 11-05-2015, 04:36 PM Thread Starter
Diesel DB
USAF93's Avatar
Quoted: 113 Post(s)
Garage
Great! I used Mobil 1 full synthetic but this time I switched to Rotella T6. Maybe I should switch back? The Magnesium was really high. Is that added lubricant? nismofan240, are you at Langley?
USAF93 is offline
post #9 of 10 Old 11-05-2015, 07:38 PM
Quoted: 2 Post(s)
Yea I'm stationed at Langley.
post #10 of 10 Old 11-05-2015, 11:49 PM Thread Starter
Diesel DB
USAF93's Avatar
Quoted: 113 Post(s)
Garage
Retired AF here. Now I work on base over by the Marina.
USAF93 is offline
