How often do you change the fuel filters??? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 11-04-2015, 06:48 AM Thread Starter
MrWicked's Avatar
Quoted: 7 Post(s)
good morning
i am using the Motorcraft filters... who has a deal on them???
im in so cal and Oreilys is the only ones that had it in stock for $55.00
how often do you change the filters???
MrWicked is offline
post #2 of 25 Old 11-04-2015, 06:55 AM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1869 Post(s)
Garage
Every other oil change, I empty the water seperator before and after snow season. I always check the secondary filter on top of the engine while changing the oil filter.
the6ohguy likes this.
Justin
2005 F250 FX4 Lariat 292k
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Powermax USA 250 amp Alt - Custom Big 3 Upgrade -
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
post #3 of 25 Old 11-04-2015, 06:59 AM
Quoted: 331 Post(s)
I too change my fuel filters every other oil change but I drain the water separator every oil change. I always use Motorcraft filters and get them wherever I can get them the cheapest which is usually online via eBay, etc.
jd4010 is offline
post #4 of 25 Old 11-04-2015, 07:12 AM
11427's Avatar
Quoted: 6 Post(s)
Garage
About every 10k miles or like everyone else said "every other oil change".
Mark
11427 is offline
post #5 of 25 Old 11-04-2015, 07:18 AM Thread Starter
MrWicked's Avatar
Quoted: 7 Post(s)
for you 2 that change every other oil change what is your oil change at 5k or 10k????
and im a dumb azz i forgot i can by Motorcraft stuff wholesale from one of my dist....
MrWicked is offline
post #6 of 25 Old 11-04-2015, 07:21 AM
ynpmoose's Avatar
Quoted: 7 Post(s)
I do every other oil change. My oil change interval is 5k.
ynpmoose is offline
post #7 of 25 Old 11-04-2015, 07:23 AM Thread Starter
MrWicked's Avatar
Quoted: 7 Post(s)
ok i can get the fuel filter for $46.65 oil filter $18.48
MrWicked is offline
post #8 of 25 Old 11-04-2015, 07:50 AM
11427's Avatar
Quoted: 6 Post(s)
Garage
I try to keep my oil changes at 5k.
Mark
11427 is offline
post #9 of 25 Old 11-04-2015, 12:05 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
I usually shop on diesel-filters.com - $39.95 and 16.25. Shipping is usually reasonable.
Sometimes (but not always) Amazon can be cheap too, especially if you have Prime for free 2-day shipping.
ynpmoose is offline
post #10 of 25 Old 11-04-2015, 12:24 PM
6.0 Junkie
the6ohguy's Avatar
Quoted: 17 Post(s)
You should never be going over 5k on oil in a diesel let alone a HEUI based truck...
2003 6.0L CCSB 4x4 999,xxx+
AKA Big Red
Original Heads, Gaskets, Pistons, Crank, Block
SCT X4 Tuned, S363.sxe, Warren 155/30s
K&N Intake, EGR Delete, Stock exhaust without muf or cat, Blue spring, stock wheels and tryes
Only have used Rotella T6, Motorcraft Filters, Archoil AR9100 and AR6200
the6ohguy is offline
