BPD 7.3 fan clutch install - Page 7 - Ford Powerstroke Diesel Forum
 8Likes
post #61 of 87 Old 09-01-2015, 09:54 AM Thread Starter
War is the answer!
WarChild's Avatar
Quoted: 29 Post(s)
Oh let me look i might be confused with someone else.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #62 of 87 Old 09-01-2015, 09:55 AM Thread Starter
War is the answer!
WarChild's Avatar
Quoted: 29 Post(s)
Originally Posted by j.mo View Post
I did this mod last summer, along with the dieselsite water pump. I'm wondering if my clutch actually works, I've never heard the fan come on. My oil Temps towing my boat through the hills make me uneasy, I'll see 220-225*, ect around 206, I have the bpd oil cooler with filter relocation like zmann.
I'd really like those oil Temps lower.
He said he did this mod... and those temps are hight for just towing a boat.
WarChild is offline
post #63 of 87 Old 09-01-2015, 11:31 AM
joe blow's Avatar
Quoted: 150 Post(s)
I am curious about something. As I mentioned I just installed the fan, water pump and switched to elc yesterday. From the moment I ran my truck after the install I heard the fan moving air..... Not fully engaged but definitely engaged. My initial test drive, I definitely heard the fan at every take off after my stop. I took it for a hard run on the freeway and temps never got above 198* and ambient temps were 90ish.
Today I drove the truck a few times and that particular fan "noise" I heard yesterday is gone. I drove the truck on the freeway and ect reached 206 and dropped with engagement of the fan.... But still not as noticeable as the initial noise I heard yesterday.
Any ideas?
Am I a victim of the infamous Hayden defective fan crowd?
Thanks
Joe
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #64 of 87 Old 09-01-2015, 12:31 PM Thread Starter
War is the answer!
WarChild's Avatar
Quoted: 29 Post(s)
Look at it this way. The thermostat is right on the front of the clutch so it's relies on the air hitting the thermostat now and not coolant and oil temps. It's going to engage and disengage way differently than before. Drive it for a few days and get use to how it reacts. Everyday is a new adventure.
WarChild is offline
post #65 of 87 Old 09-01-2015, 12:34 PM
joe blow's Avatar
Quoted: 150 Post(s)
Totally understood. It is obviously working because I can hear it engage as the temps climbed to 206 in the freeway this morning. Definitely going to have to get used to the operation for sure
Thanks
Joe
Joe
joe blow is offline
post #66 of 87 Old 01-28-2016, 09:45 AM
kbliss05's Avatar
Quoted: 4 Post(s)
Garage
so to the guys that have the 7.3 fan how is it holding up do you still like it? good for towing?
kbliss05 is offline
post #67 of 87 Old 01-28-2016, 10:17 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
Loved mine. Towed 32,000lbs without issue.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #68 of 87 Old 01-28-2016, 10:22 AM
kbliss05's Avatar
Quoted: 4 Post(s)
Garage
awesome! i think this will be my next upgrade then all aluminum radiator.
kbliss05 is offline
post #69 of 87 Old 02-01-2016, 06:29 PM
Quoted: 13 Post(s)
Anyone get a P0480 and P0528 after the swap? I did it about a month ago and now I'm throwing these codes. Not sure what to make of it. I'm not running hot and still hear the fan on start up. It never gets hot enough to kick back on since I'm not towing. Solenoid?
06 F250 6.0
IPR egr cooler, IPR external oil cooler, IPR high flow coolant filter, ARP studs, 4" turbo back exhaust w/cat delete, blue spring, Garrett stage 1 Powermax, 08+ mirrors, 3" leveling kit, bags, 51 gal Titan fuel tank, on board air, Rigid Industries LED light bar and fog lights, JVC with 2 10" Kicker subs, Kicker 6"x8" mids in the doors with separate 1" tweets in dash, sct livewire TS, projector HID headlights, Viper alarm and remote start.
6.0Dan is offline
post #70 of 87 Old 02-01-2016, 06:38 PM
Master_Chase's Avatar
Quoted: 520 Post(s)
Those codes are for the computer controlled fan clutch you replaced with a mechanical clutch. Yes those codes are normal
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
