What oil are you guys using? - Ford Powerstroke Diesel Forum
General 3.0L Discussion General 3.0L Discussion
 2Likes
post #1 of 11 Old 12-09-2018, 08:20 PM Thread Starter
Quoted: 23 Post(s)
I was thinking about using Rotella T6 5w40. According to manual should be OK.
2018 Ford F-150 King Ranch 3.0L Power Stroke 4x4 | AutoStopStart Disabled, BuiltRight Seat Release, ForScan Mods: Disable Double Honk, 2x Panic, DPF Full %
Icon 2.5 Coilovers, Fox 2.5 Rears, and 3" block waiting to be installed.
SOLD* ---> 2017 Ford F-150 Raptor 3.5L Magnetic Grey, LineX, BakFlip MX4
SOLD* ---> 2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
wreedPS is offline
post #2 of 11 Old 12-10-2018, 08:19 AM
06King60's Avatar
Quoted: 10 Post(s)
Garage
That's what I use in my 6.0...not sure about the new 3.0
API FA-4....manuel says not neither interchangeable or backward compatible API CK-4, CJ-4, CI-4 with CI-4 plus, CI-4, and CH-4 oils
2006 F250 6.0
EGR delete
Oil Cooler replaced
STC fitting replaced
ICP IPR replaced
glow plugs replaced
06King60 is offline
post #3 of 11 Old 12-10-2018, 09:24 AM
JustinOOO9's Avatar
Quoted: 1702 Post(s)
Garage
Feedback Score: 3 reviews
I was like 90% sure the book for the 3.0l calls for 5w-30. I would check the owners manual first. The 3.0l diesel is drastically different then the 6.7l in the powerstrokes. If the manual shows 5w-40 is ok though its a great oil esp for winters. My trucks runs beyond better especially in -10 with the 5w-40 full synthetic.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #4 of 11 Old 12-10-2018, 09:35 AM Thread Starter
Quoted: 23 Post(s)
In my first post I say the manual says 5w-40 CK-4 is OK.
wreedPS is offline
post #5 of 11 Old 12-10-2018, 09:58 AM
JustinOOO9's Avatar
Garage
Your first post says "according to the manual it SHOULD be ok. I was merely asking for clarification because the 3.0l diesel is still rather new etc. Plus If you are familiar with Ford they have been known to change what oil weights are acceptable after sometime each generation of diesel is out so double checking before purchasing is never a bad idea with powerstrokes.
The old 1999 f250 owners manual for my truck never mentions 5w-40 (just 15w-40 and 10w-30) being an approved weight yet is so just wanting to help clarify
post #6 of 11 Old 12-10-2018, 07:58 PM Thread Starter
Quoted: 23 Post(s)
Thank you! I ordered Rotella T6 5w40, so I hope it is OK! I think it will be... This motor has been great so far! Feels strong and tough.
According to the manual is should work fine, actually preferred for severe service. When I leave it idle for hours in the summer here in Houston, I consider that severe.
http://www.fordservicecontent.com/Fo...userMarket=USA
wreedPS is offline
post #7 of 11 Old 12-11-2018, 07:43 AM
JustinOOO9's Avatar
Garage
I think you'll like the Rotella t6 5w-40. Also check the rotella website they had a really good promotion on buying the t6 it was like $7 a gallon and $21 for the three 1 gallons jugs in a box. It may still be going on save some money.
06King60 likes this.
post #8 of 11 Old 11-18-2019, 06:41 PM
Quoted: 230 Post(s)
Cool. ......
DaveP. is offline
post #9 of 11 Old 11-18-2019, 07:31 PM Thread Starter
Quoted: 23 Post(s)
Originally Posted by DaveP. View Post
I don't know why I dropped into a 3.0 room.
Doesn't look like it is.
I found this site: 3.0L Power Stroke Diesel Specs (Ford F-150 Diesel)
Scroll down to Oil specification: It very CLEARLY says SAE 5W-30 API FA-4. It then says NOT compatible with earlier CK-4, CJ-4, CI-4, CH-4.
If I had a brand new $50,000 truck still under warranty, I wouldn't consider putting the WRONG oil in it. These aren't 20 year old tractor engines like the 7.3. There are many differences in modern engines that require the correct oil additive package. Leave it to engineers that developed and validated the engine, and use their recommended oil spec. T6 isn't one of them, in fact they say DON'T use "T-6", because it is a CK-4 spec.
Read More. CK-4 5w-40 recommended for Severe Duty. I have 15 of these in a Fleet. All they get is Rotella T6. Beautiful, solid, well built, issue free trucks so far.
Powerstrokehub.com isnt official information. I get mine from the owners manual and Ford diesel oil charts.
DaveP. likes this.
wreedPS is offline
post #10 of 11 Old 11-18-2019, 07:33 PM Thread Starter
Quoted: 23 Post(s)
Here is clippet from 2019 Owners Manual. T6 Rotella is preferred oil.
wreedPS is offline
