5.4 is absolutely worthless - Page 2 - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
 2Likes
post #11 of 29 Old 11-04-2015, 01:17 PM
6.0 Junkie
the6ohguy's Avatar
Quoted: 17 Post(s)
The 3v 5.4 is a turd i will agree, but my 2000 F-150 just rolled 200k without any problems whatsoever even running a really hot 100 low lead tune.
2003 6.0L CCSB 4x4 999,xxx+
AKA Big Red
Original Heads, Gaskets, Pistons, Crank, Block
SCT X4 Tuned, S363.sxe, Warren 155/30s
K&N Intake, EGR Delete, Stock exhaust without muf or cat, Blue spring, stock wheels and tryes
Only have used Rotella T6, Motorcraft Filters, Archoil AR9100 and AR6200
the6ohguy is offline
post #12 of 29 Old 11-04-2015, 05:55 PM
Dusten's Avatar
Quoted: 247 Post(s)
Garage
the 2v 5.4 is a good engine. The 5.0 is a great engine. My ecoboost was trouble free for almost 100k miles.
Dusten is offline
The Following 2 Users Say Thank You to Dusten For This Useful Post:
the6ohguy (11-05-2015)
post #13 of 29 Old 11-05-2015, 09:39 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1680 Post(s)
Garage
Too funny, have a buddy with a 5.4 getting the cam business fixed right now........ But I think with good synthetic oil and regular maintenance and those engines will go a long damn time without any issues. Have another friend with a 2006 and his is silent as a mouse when its running, unlike the other one that rattled more than my 6.0
Honestly I do feel Ford got a little aggressive with the engine design but the setup does make HP. which is why they followed through with it. Just properly maintain them fellas
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #14 of 29 Old 11-09-2015, 06:20 PM
fordsvtparts's Avatar
Quoted: 139 Post(s)
Definitely good advice...I think that would have helped many of them out there.
The one unavoidable issue I have seen here has been the leaking tensioners. Once the sealing O ring starts leaking, the top half of the engine gets starved of oil & the cams get wrecked. These are the same tensioners used on the older 2V engines, but seemed to have more issues. I believe the 3V uses a different pump with more oil pressure; I could only guess the added oil pressure contributes to this issue.
The Mustang guys with the 4V engines will often go to a metal tensioner (no rubber O ring to leak) but have never heard if these were acceptable to use on the 3V.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
post #15 of 29 Old 11-10-2015, 09:05 PM
mhatlen's Avatar
Garage
I was sent pictures of the engine getting the cam chains fixed. It is pretty much toast. The oil was not changed anywhere close to every 5,000 miles. It has sludge everywhere and the cam mains are badly scoured and most like the crankshaft is as well. He is replacing the entire engine!!
A real bummer for sure, he found a replacement engine with 110,000 on it and is putting it in. They went through the chains and tensioners so hopefully it's good to go.
Fella's I cant say it loud enough: Oil is CHEAP engines are not..............
It's not a bad design, but like anything else you get out of something that you put into it. Cant change the oil every 10-15,000 miles and get kicked in the as_ in the long run. He's getting it done by a Ford Master Mechanic on the side for $3,000.00. I think it's a hell of a deal, it's just a crying shame that it needs it done in the first place.
CAT EC-1 coolant
mhatlen is offline
post #16 of 29 Old 11-10-2015, 10:27 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 597 Post(s)
We sing the same tune for the 6.0 and 6.4... A 5.4 is cheap as balls compared to the diesels. I know of more than a handful of 6.0s that never would have had a problem if oil was changed properly and coolant was drained and filled ever 20-30k miles. The gassers are more forgiving in the short term but will still cost you a motor in the long run.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #17 of 29 Old 09-12-2016, 12:06 PM
frdbronco8's Avatar
I was happy with mine in an F150. Outpulled my buddies GMC with a 5.3. Also made torque at a lower RPM than the hemi.
For a f250 would be a bit small
frdbronco8 is offline
post #18 of 29 Old 09-12-2016, 03:15 PM
JustinOOO9's Avatar
Quoted: 1518 Post(s)
Garage
Feedback Score: 3 reviews
I don't like admitting it, but before I got my current 99 f250 7.3l, I looked at a 4dr,longbed f350 2004, with the 5.4v8 wow!!! I was very very disappointed my wifes 2006 corolla was faster! but I really wanted a 4dr and instead I went to a 7.3l, still not as fast as my previous 6.0's. but more then capable for what I tow and carry in the bed...
the v10 was nice, but seem hard to find these days.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #19 of 29 Old 09-15-2016, 09:47 AM
ARS1's Avatar
Quoted: 178 Post(s)
Garage
I had an Expedition with a 5.4 and the mileage sucked plus it cost a fortune to have the plugs changed on it. I know that's a expedition issue with it being pushed back so far into the firewall but I don't miss that motor. No way I'd buy a 250 with any gasser I know my Raptor 6.2 was a 9MPG guzzler I can't imagine a 250 with it in it... But on the other hand around here they're pretty cheap and can be had just about anywhere clean with low miles.
My Build Page
'17 F250 6.7L 4x4 Lariat Ult. Shadow Black -Kelderman 6"-8" Air Lift - Fab Fours Premium Bumpers - Amp XL Steps - SmittyBilt 15.5K X2O Wireless Winch - Fuel Crush 22"x14" -70 Wheels - 37"x13.5"x22" Toyo M/T's - Custom Bed Mount Spare Tire / Hi Lift Jack Mount - Horn Blasters Katrina Train Horns - S&B Intake - AMI Blue Demon Hooks - Weigh Safe 2 1/2" Receiver - Smoked Lights - LED Conversion - More To Come...
'18 Camaro ZL1 1LE - Hyper Blue
'18 Camaro ZL1 - White
'18 Jeep JL Rubicon - Blue
'17 Raptor - Shadow Black
Please Subscribe!
ARS1 is offline
post #20 of 29 Old 09-15-2016, 10:21 AM
7.3 powerchoke's Avatar
Quoted: 191 Post(s)
Actually its the complete opposite... its a horrible engine design.. not only do the cams get starved of oil once the seal goes but the cams do NOT have ANY bearings... The cam just rides directly on the cam mains in the head which is floating on a film of oil that has .001" clearance... so when the cams go they also take the heads out with it because there are no bearings to replace, so then the head becomes junk.. HORRIBLE design
7.3 powerchoke is offline
