Black box, what is it? - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 5 Old 10-22-2018, 08:10 AM Thread Starter
Hi I'm doing a cummins swap on a 97 cclb drw 7.5 460 gas v8. Theres a black box on the passenger frame rail with a hard metal tube going back along the frame rail to, i think, the gas tank? I'm wondering what its for and if I can get rid of it? I couldnt find a part number on it but it seems like the ports are labeled with letters, if I remember correctly, like a lot of different letters, maybe 9? but i think just 2 or 3 lines going into the box...a mystery. Any ideas? I'm not sure my search function works either.
BC4Lyphe is offline
post #2 of 5 Old 10-22-2018, 08:39 AM
jman37's Avatar
Quoted: 318 Post(s)
Garage
A picture is worth 1000 words.
jman37 is offline
post #3 of 5 Old 10-22-2018, 09:17 AM
Heavy_GD's Avatar
Quoted: 3099 Post(s)
Garage
Feedback Score: 4 reviews
Its a gasser, soooo... .
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #4 of 5 Old 10-22-2018, 11:51 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 593 Post(s)
Feedback Score: 11 reviews
could be the charcoal thingy but a picture would help a lot
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #5 of 5 Old 10-26-2018, 03:11 AM
RJC2's Avatar
Quoted: 690 Post(s)
It's a charcoal filter used in conjunction with gas engines. Gasoline expands and contracts much more than diesel. Gasoline fumes are explosive, so that filter takes care of the fumes when the gasoline expands as it warms up. (ie. when you fill it up at the pump where the fuel is ~55 degrees and its 80+ degrees outside)
If you're installing a Diesel, toss it.
My neighbor did a Cummins swap on his Ford. It ended up being very expensive and fraught with problems. I told him that he needed to put anti-rejection drugs in the diesel fuel.
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler
RJC2 is offline
