5.0 stalling after a letting off gas with load - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 6 Old 04-22-2018, 01:01 PM Thread Starter
Deeds86's Avatar
Quoted: 11 Post(s)
Hey guys maight not be the right place to post but already a member of this forum so here it goes, I recently acquired a 91 f150 plow truck with the 5.0... last snowfall was the first chance I got to use it, after plowing up the driveway i let off the gas it died but would fire back up did a couple more passes and everytime slowing back down with a load it would just kill... Messed around and learned it would do this anytime I was quicker on the brake slowing down it would just die, I've tried new plugs,cap,wires,fuel filter and regulator, also tried checking the fuel pump and seems to be just fine I have ran sea foam through the gas for the injectors sake and inspected throttle body which is clean, I'm kinda lost now could this be my iac or my tps what's your guys opinions I can rev it up good in neutral and will not die
Deeds86 is offline
post #2 of 6 Old 04-22-2018, 04:32 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 593 Post(s)
Feedback Score: 11 reviews
Fuel filter?
Any vacuum leaks?
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #3 of 6 Old 04-22-2018, 04:40 PM Thread Starter
Deeds86's Avatar
Quoted: 11 Post(s)
Fuel filters brand new and I'm getting proper pressure via gauge... I have checked vacuum lines visually and tried blowing through some of them I'm kinda stumped don't wanna throw sensors at it I know there's not a whole lot does iac sound right or even the tps sensor?
Deeds86 is offline
post #4 of 6 Old 04-22-2018, 04:42 PM
Quoted: 94 Post(s)
If it has a IAC valve, that's what I would look at.
Sent from my SM-G892A using Tapatalk
79jasper is online now
post #5 of 6 Old 04-22-2018, 04:45 PM Thread Starter
Deeds86's Avatar
Quoted: 11 Post(s)
Alright cool I'll give it a whirl I think an iac was in the $17 range thanks for your input I'll post back on what that does for it
Deeds86 is offline
post #6 of 6 Old 04-22-2018, 05:32 PM
BBBRRRRRTTTTT
Quoted: 593 Post(s)
I would try the iac as well.
