All things PEW PEW chatter - Page 104 - Ford Powerstroke Diesel Forum
Firearms Discussion Discussion of all types of firearms.
 1517Likes
post #1031 of 1765 Old 06-29-2017, 04:24 PM
SparkyF250's Avatar
Quoted: 3346 Post(s)
Garage
Originally Posted by Lilpooh View Post
I went with the Hornady LnL progressive. I decided to reload because shooting factory 300blk subsonic was a hit or miss with keeping the rounds from going supersonic. All my firearms are short distant calibers, here in PA with thick woods, we rarely see over 100yrd unless your field hunting.
About time, my forth form1 suppressor was approved today, submitted 7/11!!!! My first one only took 66days, 2nd took 166 days, and 3rd took 240 days.
Now need to submit form1 for SBR.
That Hornady is a nice press, now I understand why you were looking for lube alternatives. If you can find one clean enough to size rifle brass on the progressive you'll be golden. If not you may look for a cheap single stage to size on, then run primed brass thru the Hornady.
Lilpooh likes this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #1032 of 1765 Old 06-29-2017, 05:58 PM
portcity_gt's Avatar
Quoted: 1617 Post(s)
You're depressing me.
toren302, Lilpooh and SparkyF250 like this.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #1033 of 1765 Old 06-29-2017, 06:01 PM
I can understand reloading expensive rounds like my .458 socom for example.
But on the cheaper stuff, how long does it take to offset the cost of tools and supplies to reload? Just seems like you aren't saving much in the end unless it's a very long run.
toren302 likes this.
post #1034 of 1765 Old 06-29-2017, 07:51 PM
SparkyF250's Avatar
Garage
I can load up 500 rounds of 45 ACP in a couple hours, $55 for 500 plated RN, $15 500 primers, $10-$15 powder. Total $80 or about half the cost of new ammo. 9 MM you don't save quite as much, rifle is good savings and for bench rest kind of accuracy you have to reload. I started back in the 80's and got most of my tools wholesale since I had my FFL back then. I'm guessing my bench paid for itself many times over. Today you could set up a bench with a Lee starter kit with a turret press for $200.
Depends on how much you shoot and what you shoot if it's worth it.
Sparky
post #1035 of 1765 Old 06-30-2017, 05:43 AM
I guess $200 for equipment isn't too bad.
I'll likely never use enough ammo to justify it, unless I win the lotto and buy lots of land. Because I'm not paying the outrageous range prices around here.
SparkyF250 likes this.
post #1036 of 1765 Old 06-30-2017, 08:33 AM
dsalome11's Avatar
Quoted: 91 Post(s)
I try to reload everything except 9mm or .380... I also reload for the blackout, which is a huge lifesaver. most rifle rounds that I shoot(.308,300,6.5,.25-06,22-250) are all running over a dollar a round for factory I can make them for less than half. the biggest initial cost is press and brass. I use a lee turret, I started out with this as a beginner. Now I want a progressive! but for rifle reloading the turret press Is the best IMO. Living in the soon to be liberal state of AZ, I try to go shooting as much as possible, except fire season
2016 F250 6.7 CCSB Lariat Ultimate. Ingot Silver. NL stage 2 + EGR missing. DPF/CAT missing. SCT GTX-SOTF. Weathertech's. 15% tint.Rhino Lined. Rough Country Dual LED light kit. Ranch Hand Horizon Front Bumper. 2-12" Rockford Subs behind rear seat
dsalome11 is offline
post #1037 of 1765 Old 07-03-2017, 03:54 PM
JustinOOO9's Avatar
Quoted: 1670 Post(s)
Garage
Feedback Score: 3 reviews
For those who have to deal with CA.... anyone have good/bad for these little car safes?
https://www.amazon.com/gp/aw/d/B00PI...NML&ref=plSrch
I know it's not foolproof or as good as ripping out the seat and building a safe but for the on the pinch? My job takes me to state and federal government buildings often so I need something I can slide under he seat in a pinch etc. I can't modify the vehicles either :/.
Ps the sigp238 carries like a dream!
JustinOOO9 is offline
post #1038 of 1765 Old 07-06-2017, 07:20 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Not up on calis laws, but when it comes to safes, or storage, I prefer something I can get into quickly if I have to. Biometric or even the 4 key combo button ones over an actual key. Trying to insert the key and turn it under high stress could prove fatal if someone was say attacking you at the vehicle. They aren't that much more either for a bio or combo.
toren302 is offline
post #1039 of 1765 Old 07-06-2017, 08:08 AM
JustinOOO9's Avatar
Garage
I agree. This is more because I have to walk in to quite a few government buildings where a ccw is prohibited. When I drive my carry is always under my leg to reduce draw time. This was more like a deterrent to the run of the mill window peeper while I was in a meeting etc. We normally have gated parking faculties with guards though. I know a experienced thief with a pick kit, some times or even a high strength cutter could make work but just curious what others used.
Im 99% sure im getting the gun vault for my 99 f250 though it looks nice and slides in the center console so its hidden too.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
post #1040 of 1765 Old 07-07-2017, 08:21 PM
Bump To Pass!!
toren302's Avatar
9s and 40s day at the range tomorrow
Sent from my SAMSUNG-SM-G870A using Tapatalk
Lilpooh and 5.9and6.0 like this.
toren302 is offline
