2005 - 2007 F250 F350 Dimensions for Bumper Building - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
 3Likes
  • 1 Post By -Falcon-
  • 2 Post By -Falcon-
post #1 of 7 Old 02-07-2019, 05:53 PM Thread Starter
-Falcon-'s Avatar
Quoted: 391 Post(s)
Garage
Okay, Here are the dimensions of the mounting points to build those custom bumpers you always wanted to.
This is for the Ford F250 and F350 and years 2005-2007.
May also fit 99-04 as well with the retro fit for 05-07. But I have not tested that. I am not sure if the frame horns, crossmember, and Transmission Cooler (or Oil Cooler?) are in the same spot and same dimensions.
If You have any questions, post here or Private Message Me. I will not release the dimensions for the rest of the bumpers. This is for informational purposes if you wish to make your own. These dimensions are straight off the files for when I made mine. If your truck differs, then I apologize, but these worked for me.
By the way, the front of the frame horn and the 3 bolts are NOT Perpendicular. It is something like 7.5 - 10 degrees. I need to find my Angle Finder to verify, and then I will post up a side view of the bracket to show. I will update this thread when I find it and draw it up.
I forgot to give the dimensions for diameter of the 3 holes in the frame horn (where the old Tow hooks were). Those fit an M12 bolt, so 1/2" holes should work just fine.
Got Dirt? likes this.
2007 F250 Crew Cab Lariat 4x4. Lots of upgrades, but not enough. It's tall, too tall. Yes, I'm obviously compensating for something.
UPGRADES:
EGR Delete, RedHead Steering Gear, Blue Spring Upgrade, ARP Studs, (Let's not mention this manufacturers name) Coolant Filter, (Let's not mention this manufacturers name) Blue Intercooler Pipe and Elbow Upgrade, Cold Air Intake, One-Up Offroad Traction Bars, XD Wheels and Nitto Ridge Grappler 37" Tires, LED Lights all around, 2013 Tailgate, 2008+ Power Mirrors, Pro-Comp XXX Dual Front Coilover Suspension, Custom Bedliner Sprayed Rocker Panels and Fender Flares, Amerihood Tpe E-Style Ram Air/Heat Extraction Hood, CompuStar Alarm with Remote Windows, Remote Start, and much more!
More upgrades to come, including Singer Alternator, and other engine upgrades.
NEW Custom Bumpers with Tire Carrier! Dual Winches!
-Falcon- is offline
post #2 of 7 Old 02-07-2019, 05:57 PM Thread Starter
-Falcon-'s Avatar
Quoted: 391 Post(s)
Garage
Here are the pictures with dimensions for the front bumper.
Front/Rear View
Front/Rear View
Top View
Top View
G8orFord and Got Dirt? like this.
UPGRADES:
-Falcon- is offline
post #3 of 7 Old 02-09-2019, 05:54 AM
ZMANN's Avatar
Quoted: 3756 Post(s)
A big thanks to Falcon for providing this detailed information
6.0 flush pdf
ZMANN is offline
post #4 of 7 Old 02-09-2019, 05:55 PM
Originally Posted by -Falcon- View Post
Okay, Here are the dimensions of the mounting points for the Ford F250 and F350 and years 2005-2007.
By the way, the front of the frame horn and the 3 bolts are NOT Perpendicular. It is something like 10 degrees. I need to find my Angle Finder to verify, and then I will post up a side view of the bracket to show. I will update this thread when I find it and draw it up.
I will also update this with the dimensions for the rear bumper as well.
Thank you so much falcon! This helps quite a bit, I’m making one and will post pics of it while making it and any difficulty I may run into along the way
2003_6hoe is offline
post #5 of 7 Old 02-09-2019, 06:39 PM Thread Starter
-Falcon-'s Avatar
Quoted: 391 Post(s)
Garage
Let me know if you have questions. I will post the rear dimensions soon. I didn't get a chance to do it today.
UPGRADES:
-Falcon- is offline
post #6 of 7 Old 02-10-2019, 03:59 PM Thread Starter
-Falcon-'s Avatar
Quoted: 391 Post(s)
Garage
Here are the dimensions for the Rear Bumper.
Top View
Back/Front View
Side View
UPGRADES:
-Falcon- is offline
post #7 of 7 Old 02-16-2019, 01:42 PM
Quoted: 49 Post(s)
Falcon, you got a paypal or anything? Iíd like to throw you a little something for the detailed help!
Doward is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Would you buy? 2005 f250 268k miles? cmr General 6.0L Discussion 16 09-18-2018 11:47 AM
2005 2wd auto f250 6.0 any help will be greatly appreciated Zack346 General 6.0L Discussion 0 05-04-2018 08:32 AM
2013 F250 Readylift on 2007 F250? Difference in parts? cjchico4 6.0L Exterior Discussion 0 12-10-2017 02:54 PM
Front drive shafts F250 vs. F350 h0trod 99-03 7.3L General Discussion 6 09-24-2016 07:34 AM
05-07 F350 SRW much different than F250? Jakl General 6.0L Discussion 3 08-05-2016 10:42 PM
