Need some help. Got an 05 6.0 that wont start. Stuck in parking lot. Edge cts is showing codes of p0336 and p2291.
Any help or suggestions will be greatly appreciated! !
P2291 is not enough oil pressure to start te truck (500PSI) so you have a Bad IPR (more than likely) Bad ICP, bad STC fitting on the HPOP, or a bad HPOP... Id lean toward a IPR or the STC fitting on the HPOP
I am helping a man with a 2003 F-250 with the 6.0. Ford released a statement that the harness is prone to rubbing through and creating a short/fault on every point where there is tension/pressure on the 03-05's. Come to find out he had 2 spots that were worn down to metal on metal. It was amazing the truck would run at all. It had 12 DTCs total. He thought he was fixing to replace an engine. So, just a place to start
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
