Boost sensor location - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 12 Old 10-14-2018, 05:10 PM Thread Starter
Quoted: 2 Post(s)
Hey everyone,
I have a early 99 and am looking to install my EV2 boost gauge, I have my 1/8 drill &tap and it says to drill in the intake side of the spider.. I'm just not sure exactly where that is.. and all the videos out there are for 2000 and later..
Any one have a picture of there 1999 boost gauge sensor installed?
rpetty5555 is offline
post #2 of 12 Old 10-14-2018, 05:42 PM
SparkyF250's Avatar
Quoted: 3350 Post(s)
Garage
Does the early 99 have an intake heater? Most guys simply delete that and put an adapter there for a boost gauge. @[email protected] carries the adapters. www.cncfab.us
Name:	dieselsite-dieselsite-air-intake-heater-plug-for-ford-powerstroke-7.3l-gm-duramax-6.6l-01-05-for.jpg
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #3 of 12 Old 10-14-2018, 05:48 PM Thread Starter
Quoted: 2 Post(s)
No, it does not, I think they refer to it as a AIH? That did not get put on to late 1999 or 2000 models... thanks for trying to help though!!!
post #4 of 12 Old 10-14-2018, 06:24 PM
SparkyF250's Avatar
Garage
When Corey see the tag he'll chime in and see what he can do to help. He's one of our 7.3 experts, along with @LoxDiesel I'm sure one of them will help you out.
rpetty5555 likes this.
Sparky
post #5 of 12 Old 10-14-2018, 06:29 PM
Quoted: 94 Post(s)
Inlet means the side the air comes in. Meaning the side that is hooked to the turbo....
Sent from my SAMSUNG-SM-G930A using Tapatalk
1994 F350 7.3 PSD 4X4 ZF5 DUALLY
PHP HYDRA, 6637, 3-4 DP TO STRAIGHT 4 BEHIND THE TIRE, 1.0 EXHAUST HOUSING, DIY D66 TURBO, FUGA E-FUEL, EBPV DELETE. Cooper discoverer AT/3'S.
2010 VW JETTA TDI DSG Kerma tune. Hankook ventus v2 concept 2.
79jasper is offline
post #6 of 12 Old 10-14-2018, 06:39 PM
SparkyF250's Avatar
Garage
There's 3 sides hooked to the turbo, intake, hot boost and exhaust sides. My guess is somewhere on the cold side around where the AIH would be. If he puts it on the inlet he'll only be reading what the turbo is pulling in from the air filter. To read boost it needs to be between the CAC and intake manifold. IMO
JustinOOO9 likes this.
Sparky
post #7 of 12 Old 10-14-2018, 06:55 PM
Quoted: 94 Post(s)
We're talking about the intake "y pipe" here, which has 5 sides...
Not the air intake to turbo....
79jasper is offline
post #8 of 12 Old 10-14-2018, 07:05 PM
SparkyF250's Avatar
Garage
We're talking about the intake "y pipe" here, which has 4 sides...
I realize that, your last post made it sound like the air cleaner side. Just trying to clarify.
I still say put it where the AIH would be on a late 99 up. Works great right there with an AIH delete.
Sparky
post #9 of 12 Old 10-14-2018, 08:20 PM
Quoted: 94 Post(s)
I see. I thought we were passed that, since it was mentioned to use the aih hole, which he said he doesn't have.
Can also avoid drilling by tee-ing into the map line.
79jasper is offline
post #10 of 12 Old 10-17-2018, 06:48 AM
Corey@CNCFAB's Avatar
Quoted: 1460 Post(s)
Feedback Score: 4 reviews
AIH (Air Intake Heater in not on the early 99's) is only on the late 99-03's. People either drill a hole in the spider or the get a barbed Tee and tap into the MAP hose.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
