VPN - Ford Powerstroke Diesel Forum
Computer Geeks Gaming, Servers, Code, everything computer...
post #1 of 9 Old 08-16-2014, 03:41 PM Thread Starter
jesilvas's Avatar
Quoted: 5 Post(s)
VPN
Trying to setup a VPN using OpenVPN and a Netgear R7000 router. Seems straight forward, but OpenVPN shows error connecting, then sometimes connects and the loses the connection and retries.
Once it connects, the VPN connection is auto assigned an IP address, so it's not really working. WHAT DO I DO???
jesilvas is offline
post #2 of 9 Old 08-16-2014, 05:11 PM
JSchuricht's Avatar
You will probably have better luck at DSLreports or HardOCP. The settings for individual routers can be different and is also influenced by intended use and security levels.
That being said you need to determine what you are trying to accomplish with the VPN. Typically you don't set it up at the router level unless you want your entire network exposed to the VPN. For instance connecting multiple branches of a business together with IPSEC. Most home uses are to connect one dedicated computer to a business or to use as a tunnel for internet traffic typically with PPTP. Within that you also have the option of specifying internet traffic to traverse the VPN or use your local connection for better speed.
JSchuricht is offline
post #3 of 9 Old 10-30-2014, 07:09 PM
DieselClueless's Avatar
Quoted: 9 Post(s)
Garage
Just to make sure I'm understanding your use case: Your are terminating your VPN at your router (i.e. , you are connecting to it with a machine that is running an OpenVPN client, correct).
Do you have the VPN setup to hand out routes (what does your default gateway show on the machine that is connected to it)? If the route is setup : can you ping whatever the default gateway is showing as? OpenVPN can be a royal PITA. I have an R7000 as well (running ddwrt kognac).
DieselClueless is offline
post #4 of 9 Old 10-31-2014, 03:14 AM Thread Starter
jesilvas's Avatar
Quoted: 5 Post(s)
Finally got it working, sry.
Turned out, the newest version of OpenVPN wasn't working right. Downgraded to the previous one, and now it's good.
jesilvas is offline
post #5 of 9 Old 09-21-2017, 06:42 PM
If that ever fails I find NordVPN is awesome
EPower is offline
post #6 of 9 Old 04-06-2018, 01:07 AM
Quoted: 2 Post(s)
express vpn works most effectively
BobBrian is offline
post #7 of 9 Old 09-13-2018, 04:30 AM
Anti-Medic's Avatar
Quoted: 16 Post(s)
Garage
I am a fan of nordvpn as well
Retired Army 93-13
Paramedic
Anti-Medic is offline
post #8 of 9 Old 09-13-2018, 04:35 AM
Heavy_GD's Avatar
Quoted: 3097 Post(s)
Garage
Feedback Score: 4 reviews
FWIW, this is from 2014....
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #9 of 9 Old 06-14-2019, 07:57 AM
Quoted: 2 Post(s)
I like nordvpn too
Solmercon is offline
