How wide of tires for a F350 Dually? - Page 2 - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
 8Likes
post #11 of 15 Old 01-31-2017, 08:11 PM
00t444e's Avatar
Quoted: 596 Post(s)
I believe you can get by with 265s on a dually with no rubbing. I have a buddy that has 265/75/16 on his Chevy dually and has no rubbing issues and he tows a goosneck regularly. The spacing on all dually trucks is about the same.
Onawave likes this.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #12 of 15 Old 01-31-2017, 08:16 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 2643 Post(s)
Feedback Score: 4 reviews
Not true sir.
EDIT for clarity: Not only does it differentiate between manufacturers since they use different offsets in their wheel sets, but it also matters if the wheels are all aluminum, steel/aluminium combo, or all steel.
Onawave likes this.
2017 F250 CCLB KR "Nighthawk" Edition.....goodies to come.
nighthawk285 is offline
post #13 of 15 Old 01-31-2017, 09:46 PM
SuperCrutyPS's Avatar
Quoted: 628 Post(s)
Garage
Paul, have you looked @ the Toyo Open Country H/T? I see you're in Oregon so check with Les Schwab. They carry Toyo tires. I was looking at the H/T & the A/T IIs. I ended up with the A/T II.
Just a thought.
Onawave likes this.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB
5th Wheel |
Proud US Navy Veteran | '76-'80 - Petty Officer 2nd Class (E5) - U.S.S. Point Defiance (LSD-31) - 'Gator Navy
SuperCrutyPS is online now
post #14 of 15 Old 02-01-2017, 04:37 AM
00t444e's Avatar
Quoted: 596 Post(s)
Originally Posted by nighthawk285 View Post
Not true sir.
You're probably right, I have never actually measured the offset but I know that dodge, Ford, and gm all have about the same spacing between the factory dually tires. Maybe a .5 - .75 inch difference between them all.
00t444e is offline
post #15 of 15 Old 02-02-2017, 08:27 AM Thread Starter
Onawave's Avatar
Quoted: 9 Post(s)
So I took the truck back to Walmart to ask them how to get these tires off and order some new ones.. The manager asked why I wasn't happy. After telling him why, he asked to see the truck.. One look and he said they guys here over inflated the tires.. He showed me only the center 4 inches were touching the ground. (I never really looked) There was 80 PSI.. he dropped each one down to 70 PSI. He said drive it like and see if it's any better. If not, just order what I want and I get a full credit. So, I drove home and did some extra driving.. WOW..these tires are awesome now. No need to replace.
SuperCrutyPS likes this.
Onawave is offline
