RV Mod thread - Page 69 - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
 247Likes
post #681 of 726 Old 07-09-2015, 08:17 PM
MooreSix0Stroker's Avatar
Garage
Great 4th of July weekend. Can't wait for my 10 day vaction to Michigan
john galt likes this.
John
07 F350 cc/sb Fx4 Lariat
ARP studs, OEM
head gaskets, 4" exhaust turbo back 6" tip, egr delete, BPD oil cooler and filtration, sct turner, egde insight monitor, coolant filter, high idle mod, Recon smoked mirror and cab markers
MooreSix0Stroker is offline
post #682 of 726 Old 07-10-2015, 05:25 PM
Pirana's Avatar
Great thread! Just read all 68 pages! I've also done a lot of mods to my RV...I'll take some pics and share them later.
2010 Ford F250 Lariat FX4
Pirana is offline
post #683 of 726 Old 07-17-2015, 09:24 PM
Teachagmech's Avatar
Quoted: 489 Post(s)
Garage
Update. My step up voltage converter kicked the bucket today on my solar. Ordered a new one online today from Amazon that is a 10A instead of a 3A. I read the wattage wrong on the first one I think. Oh well. 33 bucks and prime gets it here on Sunday guaranteed. Leaving Monday for pismo so I'd like to soak up the sun instead of running the genny just to recharge the battery.
I also built a new bottom step as a landing. The trailer had an axle flip done but they didn't bother putting a 3 tread step on. I meant to snap a pic, but I forgot and it's packed already.
Sent from my dumb smartphone
Mike"Training our future. One misfit at a time"
2005 F-250 CCSB FX4 LARIAT 191K blue spring, coolant filter, DC Power alt. Studs, BPD EGR cooler, and
[/CENTER]
Teachagmech is offline
post #684 of 726 Old 07-18-2015, 04:08 PM
Quoted: 489 Post(s)
Garage
Man, when it rains, it pours! I was dropping the stabilizers on my trailer today getting it ready for our trip Monday to watch the frame rail suck up against the bottom of the coach. The rack I made for the generator was just too much for the wimpy frame under the trailer. Looks like that's coming off. :realmad:
[/CENTER]
post #685 of 726 Old 07-18-2015, 07:03 PM
Ontario Trucker's Avatar
Sorry to hear all that Mike, hope you can fix it up for the trip
I guess you have to huh
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #686 of 726 Old 07-18-2015, 07:14 PM
Vannnce's Avatar
Quoted: 13 Post(s)
bought one of the p3 brake controllers since i fried my last controller. Moving the fifth wheel 530 miles next week, Im excited to try it out since ive heard nothing but good things
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
[center]
dlr
Vannnce is offline
post #687 of 726 Old 07-19-2015, 05:19 PM
Quoted: 489 Post(s)
Garage
I got the rack unloaded all except for a few chunks of plywood to keep the wind from burying the trailer in the sand. It'll carry that little weight just fine.
I built a spare tire mount since when I put the rack on the back, the spare tire was displaced. It's been riding around in bed of the truck the past few trips and is always in the way.
It seems like a great spot, it's over the kingpin so it doesn't effect balance, it's not bouncing around, and it's still easy to get to.
I put it over the flag pole mount so I can still put up my Stars and Stripes
[/CENTER]
post #688 of 726 Old 07-26-2015, 06:22 PM
Quoted: 489 Post(s)
Garage
A friend of mine told me about this. Seems pretty sweet so far:
If you've ever wrestled with your outdoor carpet to get it rolled up straight and tight, this is for you.
I had a piece of ABS left over from a bathroom remodel
So I cut it to length so it was the same as the width of my carpet. Then cut a slit out of it along the length. It's about 3/8" wide. Used the table saw with the blade barely high enough to get through, then turned it and cut it again.
Then I slipped the edge of the carpet into the slit, then rolled it up using the pipe as the core.
It's nothing new, but it's kinda handy!
Vannnce likes this.
[/CENTER]
The Following User Says Thank You to Teachagmech For This Useful Post:
7.34ever (08-02-2015)
post #689 of 726 Old 07-26-2015, 06:43 PM
Great trick Mike, thx for sharing......... I usually wrestle with them, lol
post #690 of 726 Old 08-02-2015, 06:31 AM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Just another addition to the PVC uses arsenal for those with toy haulers......use some PVC strapping with self-tapping screws to mount a 7-8ft length of PVC to the framing inside the top of your storage to slide your atv flags into. Works great for giving those pesky flags a home to go to when traveling so they're not beating up the inside of your trailer.
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
