Onboard Air system - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
 1Likes
  • 1 Post By Got Dirt?
post #1 of 8 Old 04-12-2019, 04:31 AM Thread Starter
Quoted: 11 Post(s)
Onboard Air system
Hello,
Anyone running a onboard air system? If so what do you do with it?
I'm looking to install a Vixen 5 gallon Dual compressor 200psi. Here is what I want to achieve from the system, We just purchased a 5th wheel so, downtime is not what I want.
Here is what I want from the system, Add air to tires (i know it can do it) run a bottle jack for changing tires, Also run an impact wrench for the lung nuts.
What are your thoughts total price installed is a grand or is it a waste of money
smt211 is offline
post #2 of 8 Old 04-12-2019, 09:36 AM
joebuck's Avatar
Quoted: 155 Post(s)
Originally Posted by smt211 View Post
Hello,
I just installed a viair constant duty with the 2.5gal tank last weekend, works great, I have its set up with 2 ports to choose from one on the back and one near the passenger door I use it for filling up my air bags after hooking up to our 5th wheel toy hauler and adjusting tires and adding psi to tires on quads or dirt bikes while were out riding, I paid $275 for the kit and installed it myself its of YouTube videos on it took 3hrs to do it all and wire it once I had all the parts and pieces
2012 F350 CCLB Lariat Ultimate/EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5 exhaust/2.5 BDS Leveling kit on 35s/Fox shocks/20 XD grenades
joebuck is offline
post #3 of 8 Old 04-12-2019, 09:58 AM
ChrisSki's Avatar
Quoted: 588 Post(s)
My compressor puts out 6.16 cu ft / min, so should fill the tires quickly but doesn't. I take my 32" tires from 65 PSI road to 25 PSI 4WD on some trails, and it takes me 30 real minutes from start to finish to put air back in the tires when I'm done. Only thing I can think is the valve stem limits how much air goes in the tire, so if that's true, it doesn't matter how strong your air compressor is or how big the reservoir tank is, the tires will take forever to fill because of that valve. Also, when I take the air out, I remove the valve stems, and it takes about 7 real minutes start to finish to empty the air. If I left the valve stems in, it would probably take me 30 minutes.
For filling the RV tires, or topping off the tires on the three vehicle have the 6.16 Cu ft / min twin ARB 12 V compressor is more than enough for that.
I would like to hear from some others. I can't be the only one putting 40 PSI in the tires to return them to road worthy after being off road. I've also been told, the only way to get that tire inflated as quick as I want it would be a CO2 tank.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 8 Old 04-12-2019, 09:27 PM
Got Dirt?'s Avatar
Quoted: 186 Post(s)
Garage
I've been using a Powertank for the last 13 years and it has always been very dependable. If you never seen one here's one of the many videos on the web.
ChrisSki likes this.
People are like dirt. They can either nourish you and help you grow as a person or they can stunt your growth and make you wilt and die.
Plato
SE VILE SE ERGO
FORTIBUS ES ENERO
NOVILE DEUS TRUX
VATIS INEM CAUSAN DUX
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight w/ EGT & Fuel Press. - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust - '08 Transmission Pan and Filter..... and a Partridge in a Pear Tree!
Got Dirt? is offline
post #5 of 8 Old 04-14-2019, 01:51 PM Thread Starter
Quoted: 11 Post(s)
Nobody is mentioning about running air tools (changing tires and a bottle jack) is this to much for a system
smt211 is offline
post #6 of 8 Old 04-14-2019, 02:06 PM
Quoted: 5 Post(s)
I have the Viair constant duty 2.5 gallon. I've used it with harbor freight 20 ton bottle jack. It will do it, but is inadequate. I've not tried air tools. While I love the compressor and tank for tires and adjusting air bag suspension, I don't think the size I have produces enough CFM for the jack or anything but the smallest air tool.
2009 6.4L CCSB Lariat
Gearbox Z DPRF
Bypass coolant filter
ericinboca is offline
post #7 of 8 Old 04-14-2019, 04:36 PM
R&Rpowerstroke's Avatar
Quoted: 107 Post(s)
Garage
I have an 8 gallon tank with 2 viair compressors running my train horn, air bags, blows out water lines on my 5er airs up tires on truck and trailer, used it for hydraulic jack, and if needed I can run a impact gun. I have around 1000 in my setup but I am happy with it and will always have oba on my trucks for now on.
03 250 ccsb blue spring, UCF ported and polished heads, Odawg SR3, ficm tuner, SCT x4 with custom tunes, 4" turbo back to 6" tip, Magtec diff covers, Amsoil fluids, ARP 625's, Airlift bags, Kc stage 1, Dieselsite hpop, Vision Hauler 19.5's, No Limit intake, full on board air with 8.5 gallon tank, train horns, Sinister degas, DieselSite water pump, Big Wig rear sway bar, 7.3 clutch fan, BPD adapter
Wife's new ride 2019 F450 Lariet Ultimate CCLB 4x4
R&Rpowerstroke is offline
post #8 of 8 Old 04-14-2019, 06:02 PM Thread Starter
Quoted: 11 Post(s)
sounds like the system i'm looking at, and for the same price.
smt211 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stock fuel system with dual Bosch pumps Boostedstroker 99-03 7.3L Performance Parts 1 05-30-2018 08:41 AM
brake pressure sensor aerialbug3 General 6.7 Discussion (2011-2016) 3 11-09-2017 04:41 PM
2002 7.3 350 two tank system w/ onboard filtration diagram Kadidlehopper Bio-Diesel/Alternative Fuels and Supplements 0 10-08-2017 01:45 PM
Injection System Explanation mschn99 Dieselmann's Links 0 12-12-2006 09:29 AM
Trouble Codes Marty 99-03 7.3 Repair Help 0 11-19-2006 07:35 PM
