SVO Conversion: 1 Year update - Page 6 - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #51 of 55 Old 10-01-2010, 02:05 PM
Originally Posted by tubular031 View Post
JIC fittings do not leak and do not need tape on the joints. finger tight then bump them with a wrench... DONE no leaks at all! I cut the hose with a dremel cutoff wheel. Make sure you wrap the ss beaided hose with tape or it will fray. yes this hose is a bunch more than rubber but it will last and will not leak
I'm going to look into this idea some more, but I'm pretty sure I'd have to order both the hose and JIC fittings online. The main thing is I'm not sure how much hose I'm going to need yet. Guess I need to get everything mounted and take some measurements.
Fanderson is offline
post #52 of 55 Old 10-01-2010, 02:09 PM
ridiculously_necessary's Avatar
Originally Posted by Fanderson View Post
Yes, I'm in Western MT so it gets pretty cold. Not much salt on the roads though, mostly sand and gravel. Which one are you implying is better?
just suggesting mounting the pump under the hood, where its warm and salt/dirt/water free.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #53 of 55 Old 10-01-2010, 02:13 PM
^^^^That is very good advice!^^^^
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #54 of 55 Old 10-01-2010, 02:36 PM
I like the idea, but I'm not sure that I'd have enough room for the and post pump fuel filters. I guess I could put the pre-pump filter down by the pollak valve, but the post pump filter would have to go under the hood somewhere.
post #55 of 55 Old 10-04-2010, 06:16 AM
mike suggested mountign the filter to the alternator or ac compressor bolts, make a bracket. i dont know how vibration would bother it, if at all, but thats a great open space and probably what i will do.
-Matt
DIY 6637
Marinco Mod
