Tune cutting out - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 03machstock
post #1 of 5 Old 01-24-2020, 07:21 AM Thread Starter
03machstock's Avatar
Tune cutting out
Hi guys,
Iv got an e99 7.3 6 speed with beans tunes on a 6 position ts chip iv been running for about 6-7 years. Truck runs great, other than recently when driving and your on a tune other than stock, the tune will cut out like the chip is losing connection and act like no chip is installed, then cut back in to the higher hp tune. This does not happen on the stock tune. Connection seems to be good and tight down by the ecu. Any ideas? Chip going bad?
Thanks,
Dan
e99 F-250 Regular cab lariat 4x4 manual transfer case, 6 speed 7.3
Warn Premium Hubs
Isspro ev2 Pyro and Boost
6637
MBRP 4" with muffler
Rigid D2's
03machstock is offline
post #2 of 5 Old 01-24-2020, 08:28 AM
Quoted: 478 Post(s)
Feedback Score: 3 reviews
Over the years, vibration takes a toll on connections. If you look at the "edge" connector on the PCM pc board you might have a hard time actually seeing a bad spot. I would re-tin (re-flow) the solder on those pads first (or find someone who has "solder skills" if you don't )
If that "free fix" didn't do it, then maybe replace the 6-pos rotary switch, could be in those contacts too...
NoRalPh is offline
post #3 of 5 Old 01-24-2020, 08:47 AM
JustinOOO9's Avatar
Quoted: 1710 Post(s)
Garage
Not sure the guy im about to mention is super popular here but... The guy from DP-Tuners used to have a service for the tinning on ecms. May be worth reaching out to him or a local guy if you're not comfortable. The ecms for these 20+ yr old trucks are getting hard to find.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #4 of 5 Old 01-24-2020, 09:38 AM Thread Starter
Thanks for the replies guys, I have a couple buddies that might be able to help me out, I’ll start there.
Warn Premium Hubs
6637
Rigid D2's
post #5 of 5 Old 02-05-2020, 09:54 AM Thread Starter
Looks like the re tinning did the trick guys! I had my buddy’s Kevin and Brian over at Fitch Electronics do it. Not sure what the DP guys used to charge but give them a call if you’d in need of this.
JustinOOO9 likes this.
Warn Premium Hubs
6637
Rigid D2's
