AC clutch not disengaging, coil unplugged - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-07-2019, 04:53 PM Thread Starter
Quoted: 72 Post(s)
My AC stopped working recently while on the freeway. Iíve unplugged the coil (and verified 12v+ on the connector when AC is on), the clutch is locked to the pulley and does not disengage. I assume I need to replace the clutch and coil, anything else I should replace at the same time? Itís a 2000 in case that makes a difference.
Krel is offline
post #2 of 9 Old 11-07-2019, 05:25 PM
Quoted: 413 Post(s)
Garage
The bearing is locked up in the clutch -- just put a new one on if your compressor is ok
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 9 Old 11-07-2019, 05:30 PM Thread Starter
Quoted: 72 Post(s)
The system is not cooling at this point, if the clutch is frozen would that prevent the compressor from doing its job? I would expect that would be the case?
Krel is offline
post #4 of 9 Old 11-07-2019, 05:37 PM
Quoted: 413 Post(s)
Garage
The clutch being locked to the rotor would make the compressor turn all the time -- if I read your comment correctly
Sounds like the front seal on the compressor may have went out with the clutch
Would be easier for me at least to just put on a new compressor, since you get it all
if the system is down on pressure, would be a good time to replace the orifice tube as well
General note:
Hydro is offline
post #5 of 9 Old 11-10-2019, 12:01 PM Thread Starter
Quoted: 72 Post(s)
I replaced the compressor today, the old one was definitely shot. Unfortunately the connection between the dryer (which I was also replacing) and the evaporator (which I wasnít replacing) was frozen and I kinked the evap side of the tube trying to get them apart. Evaporatorís on order, looks like Iíll have to pull the intercooler pipe on that side to get into the box to swap it out.
Krel is offline
post #6 of 9 Old 11-10-2019, 04:18 PM
Quoted: 413 Post(s)
Garage
Put a small amount of anti-seize on those threads in case you ever need to be in there again
Replacing the orifice tube as well? right
General note:
Hydro is offline
post #7 of 9 Old 11-10-2019, 05:57 PM Thread Starter
Quoted: 72 Post(s)
Yep, the kit includes the compressor, dryer, tube.
Sent from my iPhone using Tapatalk
Krel is offline
post #8 of 9 Old 11-11-2019, 07:41 PM
Turbostang500's Avatar
Quoted: 6 Post(s)
Since you had a compressor failure and you are opening up the system, you might as well pull the condenser out and get it cleaned out. Most of the trash from the compressor will be caught in the condenser and screen on the orifice. It would suck to go through all this work and then push a bunch of trash into the orifice right after recharging.
It is said, there should be an ounce or possibly two of oil in the condenser. The rest should be in the compressor and dryer.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #9 of 9 Old 11-13-2019, 06:45 AM Thread Starter
Quoted: 72 Post(s)
Iíll do that. Turns out the minor leak from my upper radiator hose was a cracked neck on my radiator, so Iím doing that at the same time, might as well do it all.
Krel is offline
