Front Brakes Locked Up - Ford Powerstroke Diesel Forum
 6Likes
  • 2 Post By zsargent
  • 1 Post By Hydro
  • 1 Post By Hkxyz
  • 1 Post By hansel
  • 1 Post By zsargent
post #1 of 10 Old 09-10-2019, 10:14 PM Thread Starter
Hkxyz's Avatar
Quoted: 2 Post(s)
I have a 2000 7.3, got in it today to drive a mile or so and noticed that it felt like the brakes were applied and so I drove back home and the front brakes are locked up, both sides
Jacked up the rear and they seem to be spinning freely.
I opened the bleeders on both sides and on the MC and they are still locked.
Unscrewed the MC from the hydroboost to see if something was stuck there and still locked up
Will try to take the calipers off tomorrow and go from there. If anyone has some imput please let me know
Truck is in CA so no excessive rust on any of the parts.
Thanks
DR 6" Lift on 36.5 Falkens
5150's All around
Plain and Simple Black Cragar's
And a Gallon of Black Paint
Hkxyz is offline
post #2 of 10 Old 09-11-2019, 12:45 AM
It is What IT is
Quoted: 436 Post(s)
Pistons are frozen inside the calipers or
caliper slide pins need to be cleaned/lubed or
both
jokester00 and Hydro like this.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #3 of 10 Old 09-11-2019, 05:52 PM Thread Starter
Hkxyz's Avatar
Quoted: 2 Post(s)
Took the calipers off, pressed in the pistons to see if they would move and all is good. Pressed the brake pedal with the calipers off to check to see if the pistons were both moving together and they are.
Put them back on and started the truck, pressed brake and they are locked again. Something is not letting then release?
5150's All around
Hkxyz is offline
post #4 of 10 Old 09-11-2019, 05:59 PM
Quoted: 517 Post(s)
Garage
The slide pins are bound up -- if the problem was hydraulic, then opening the bleeder would have fixed it
jokester00 likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #5 of 10 Old 09-11-2019, 07:20 PM Thread Starter
Hkxyz's Avatar
Quoted: 2 Post(s)
The slides pins are greased and clean from rust, they moved freely when i took the caliper off
Hydro likes this.
5150's All around
Hkxyz is offline
post #6 of 10 Old 09-11-2019, 08:12 PM
hansel's Avatar
Quoted: 387 Post(s)
If the slide pins are moving freely, then you might need new calipers.
2001 7.3L CCSRW 4X4
2003 7.3L CCDRW
S&B intake, 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission. Edge SCT2
PHP Hydra chip's
2015 Heartland Prowler
hansel is offline
post #7 of 10 Old 09-12-2019, 01:11 AM
It is What IT is
Quoted: 436 Post(s)
Your calipers need to be replaced. Pistons are phenolic and over time they deform.
You probably have some crud in there too. So either rebuild them (if you'v enever done it, don't) or get new ones....
Zach
168,084 miles....
zsargent is offline
post #8 of 10 Old 09-12-2019, 10:16 AM Thread Starter
Hkxyz's Avatar
Quoted: 2 Post(s)
I have 1 new one for the front that someone gave me a while back.
Thanks for the advice but why would both sides lock up at the exact same time...
The brakes have been feeling just crappy. Not what they used to be years ago. I did the rear 3 years ago, rotors calipers pads, and did the flush for the PS system. Didn't notice much of a difference.
Ive read almost every thread possible on the brakes locking up and a lot of people have had this problem, and a lot of them end up replacing everything ( rotors calipers and pads) and nothing changes. A few replaced the MC and that works for them. Other replaced both the hydro and the MC and it worked and the other 90% did not come back a report the fix...
My hydroboost has no noticeable leaks on the engine side or leaking on the floor.
I am trying to not replace everything on the axle side because I want to put the 05 axle in and ill have to go through that one as well.
Thanks for the help. Ill put the brand new calipers on and see if that helps and if it does ill get one for the other side..
5150's All around
Hkxyz is offline
post #9 of 10 Old 09-12-2019, 11:04 AM
Quoted: 21 Post(s)
Change the soft lines too while you are dong calipers. I had one fail on the inside and it acted like a check valve...
ugly96 is offline
post #10 of 10 Old 09-12-2019, 11:24 AM Thread Starter
Hkxyz's Avatar
Quoted: 2 Post(s)
YES i did read that a few times as well.
I just put one new caliper on that i had and bled it real quick hopped in and started the engine, pumped it a few times and it will spin for me but still drags on it a little.
I have stainless lines in the front, are there are rubber ones somewhere else? or just from the caliper to the frame.
5150's All around
Hkxyz is offline
