Hard thump/bump when getting off the throttle - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 15 Old 08-29-2019, 06:40 AM Thread Starter
Quoted: 12 Post(s)
I am having a thump/bump when getting off the throttle and when getting back into it. It's worse when I get off the throttle suddenly and when almost goes away when I get out of it slowly. It's almost like someone is kicking the bottom of my seat. My truck is a 2002 F-250 4x4 with an automatic transmission.
Thanks
Buddylee is offline
post #2 of 15 Old 08-29-2019, 06:47 AM
SuperCrutyPS's Avatar
Quoted: 621 Post(s)
Garage
A couple of things come to mind.
From personal experience, check the drive line to T-case coupler. Several years ago, I found a bolt on my driveway. Crawled under to see where it came from. It was from that coupler...and several other bolts were loose too. It was clunking back and forth.
2nd, do you have a two piece drive shaft? If so, check the slip yoke. They need to be greased from time to time.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB
5th Wheel |
Proud US Navy Veteran | '76-'80 - Petty Officer 2nd Class (E5) - U.S.S. Point Defiance (LSD-31) - 'Gator Navy
SuperCrutyPS is offline
post #3 of 15 Old 08-29-2019, 12:44 PM
ThaChad's Avatar
Quoted: 2 Post(s)
Rear driveshaft center support carrier bearing. The rubber there will disintegrate. Happened to me causing my bump on initial acceleration and deceleration.
ThaChad is offline
post #4 of 15 Old 09-03-2019, 03:56 PM Thread Starter
Quoted: 12 Post(s)
Thank you, I will check all of these out
SuperCrutyPS likes this.
Buddylee is offline
post #5 of 15 Old 09-05-2019, 08:16 AM Thread Starter
Quoted: 12 Post(s)
Taking the truck in to get a Teflon service on the driveshaft. Also going to get the rear diff serviced and checked out because I hear a howl at certain speeds. I will update with the results.
Buddylee is offline
post #6 of 15 Old 09-06-2019, 06:05 PM
Quoted: 3 Post(s)
REAR DRIVE SHAFT, CARRIER BEARING OR U-JOINTS.STAY AWAY FROM MOOG PARTS THEY WERE BOUGHT OUT NOW THERE PARTS R JUNK I ALREADY FOUND ONE OF THE CUPS ON A NEW U-JOINT WAS MISSING A NEEDLE BEARING REALLY !!!!!!!!!!!!!!!!
ginny1966 is offline
post #7 of 15 Old 09-06-2019, 06:55 PM
ThaChad's Avatar
Quoted: 2 Post(s)
Buddylee, be sure to post your findings after your test drive. I did hear the same about Moog parts. I've still had good luck with them but I've heard their quality control tanked. Did they sell out to some Chinese company? I dont mean to change subjects. But itll be good info before I rebuild another driveline. Usually I try to go with Spicer.
ThaChad is offline
post #8 of 15 Old 10-01-2019, 02:33 PM Thread Starter
Quoted: 12 Post(s)
I just got the truck back from the shop yesterday. Turns out it needed carrier bearings, ring and pinion, and hub bearings. I had the Teflon grease treatment, new u-joints, and a balance done on the drive shaft while they were at it. So ya basically almost all new from the transmission back now lol. The noise is gone and it's much smoother now. I will have a better impression after I get through the breakin period.
Buddylee is offline
post #9 of 15 Old 10-14-2019, 03:35 PM Thread Starter
Quoted: 12 Post(s)
Update: Getting this work done fixed the loud howl at highway speeds but it did not fix my slack in the drivetrain. I will be taking it to a transmission shop on Wednesday to have them look at it. It must be in the transmission or the transfer case. It almost seems to be an issue with the torque converter.
Buddylee is offline
post #10 of 15 Old 10-14-2019, 04:13 PM
Corey@CNCFAB's Avatar
Quoted: 1424 Post(s)
Feedback Score: 4 reviews
Did the driveline shop not check the clutches in the diff?
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
