New glow plug problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-16-2019, 09:39 PM Thread Starter
Until this past June I had been putting off changing my glow plugs. I had 2 codes for glow plug circuit 5 and 8. Smog was due end of June so I decided to replace all 8 glow plugs. I also replaced the under valve cover gasket and wiring harness while I was in there. I used all Ford Motorcraft OEM parts not wanting to take any chances with aftermarket. Passed smog just fine. About 2 weeks and only a few hundred miles later, the service engine light comes on. I get a P0676 glow plug 6 circuit code. I clear the code thinking maybe just a glitch in the system since all glow plugs are new. Next day service engine light is back on, and this time I get glow plug circuit codes for cylinders 1, 3, 5, AND 6! The truck is starting fine, but it's pretty warm here right now. Anyone have any ideas what could be going on? HELP!
kaliona is offline
post #2 of 6 Old 07-18-2019, 02:56 PM
greenskeeper's Avatar
Quoted: 299 Post(s)
CALI truck with a glow plug controller?
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #3 of 6 Old 07-18-2019, 08:44 PM Thread Starter
It is a California truck. Will a bad glow plug controller cause the codes I'm getting right after installing new plugs?
kaliona is offline
post #4 of 6 Old 07-21-2019, 05:22 PM
Quoted: 299 Post(s)
Not familiar with the GPC trucks, Aside from pulling each glow plug and confirming good glow with 12v applied, I'd wait and see how it does once colder weather sets in. If it struggles to start then I would investigate further. I also believe in not spending money if I don't have to.
post #5 of 6 Old 07-22-2019, 09:05 PM Thread Starter
Pretty warm here right now. Mid 90s during day and upper 50s at night. So it won't hurt to keep running the truck with the P0671, P0673, P0675, and P0676 codes??? I just passed smog, so if its not hurting anything I can take my time trying to troubleshoot this problem.
kaliona is offline
post #6 of 6 Old 07-25-2019, 12:40 AM
Quoted: 20 Post(s)
if it starts and runs fine it won't hurt anything.
I would ohm out the glow plugs from the main valve cover harness to start. I always check everything just in case; never know if you accidentally didn't get the connectors all the way on or something.
I can't recall if there is a way to test your gp controller like you can a gp relay.
It almost sound like there is a bad connection to those glow plugs or something. I had a buddy with a bad gp controller but he got a specific code for the bad controller; nothing about individual glow plugs.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans, 1023, SDK, GH tuned, 250/100 FF inj's, Irate T4 w/369sxe, Swamps hvhf IDM, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete,
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Donaldson Blue(6637)/AFE BHAF, RR Boots, Ford 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
